Codes to calculate diffusion parameters of homogeneous reactor
In summary, MCNP does not have diffusion coefficients as an input, but a diffusion theory-based code like Serpent or OpenMC might.
DeltaMed910
TL;DR Summary
What codes can calculate diffusion coefficient D and thermal diffusion area L^2 of a given homogeneous, reflected sphere reactor?
For a novice research problem, I am approximating a system as a spherical reactor of homogenized natural uranium and heavy water, reflected by infinite graphite. I was attempting to find the critical mass and dimensions for it (very similarly to Lamarsh 3e Ex.6.7-8). To do so, I need to calculate the diffusion coefficients D and thermal diffusion area L^2 of the homogenized core and the reflector.
While Lamarsh lays out how to do it by hand, I am also interested in what codes can calculate this for a given mixture. I do not see any entries about diffusion parameters in the MCNP manual (I have a copy of MCNP6.2).
This source has pretty much what I'm looking for, a code that calculates thermal neutron diffusion parameters for arbitrary mixtures, but it seems to have problems with hydrogenous media.
https://inis.iaea.org/collection/NCLCollectionStore/_Public/27/017/27017643.pdf
DeltaMed910 said:
TL;DR Summary: What codes can calculate diffusion coefficient D and thermal diffusion area L^2 of a given homogeneous, reflected sphere reactor?
MCNP is a general-purpose, continuous-energy, generalized-geometry, time-dependent, Monte Carlo radiation transport code designed to track many particle types over broad ranges of energies, so one will not find diffusion coefficients as input.
I would imagine a diffusion theory based code would calculate, and perhaps output, diffusion coefficients, if the code is so designed.
I'd say the chief advantage of a one group analytical solution is that it can be done on a bit of paper and produce an answer. MCNP however simulates the physics and so doesn't use any of that analytical maths internally. I did a little doodle in MCNP which may help if you want to play with the numbers.
Code:
Reflected homogeneous sphere.
1 1 -1.11 -1
2 2 -1.8 1 -2
3 0 2
1 so 50
*2 so 10000
mode n
imp:n 1 1 0
kcode 10000 1.0 10 30
ksrc 0 0 0
m1 92235 8.7E-5 01002 2 08016 1
mt1 hwtr.10t
m2 06012 99 06013 1
That's a 50cm sphere of D2O surrounded by a 100m sphere of d1.8 graphite. 8.7e-5 molar amount is just under critical and 8.8 is just over critical. The 100m sphere is reflecting but changing this makes no difference to the result so it's as close to infinite as it needs to be I think.
Changing the material to natural U will require a big change in geometry.
m1 92235 8.7E-5 01002 2 08016 1 92238 0.01234
Would be the equivalent with natural U, but this may be hopelessly dilute and you may need to alter the density in the cell section.
Edit, added S(alpha,beta) table which affects the answer slightly. 8.7 now shown to be a bit overcritical.
What is the purpose of these calculations?
One-group diffusion theory is going to have "limited accuracy". If you are just doing a back of the envelope calculation, this is fine and you can find values of one-group cross sections and L^2 and D in most introductory reactor physics books. (The older Lamarsh and Duderstadt and Hamilton have tables for many different fuel and reflector material). There is also an older (and very big) report called ANL-5800 that has tables of one-group cross sections.
If you want something more accurate, the easiest thing to do would be use MCNP, or some other Continuous Energy Monte Carlo code. Like @Alex A demonstrated, the input is fairly easy for simple geometry with no feedback.
If you want to go one step further, you can use the Serpent or OpenMC Monte Carlo codes, and these codes will produce one-group cross sections and diffusion coefficients as edits.
Likes Alex A
Related to Codes to calculate diffusion parameters of homogeneous reactor
What are diffusion parameters in the context of a homogeneous reactor?
Diffusion parameters in a homogeneous reactor refer to the coefficients that describe how neutrons move through the reactor material. These parameters include the diffusion coefficient, which quantifies the rate at which neutrons spread out, and the absorption cross-section, which measures the likelihood of neutrons being absorbed by the reactor material.
What kind of codes are used to calculate diffusion parameters in a homogeneous reactor?
The codes used to calculate diffusion parameters in a homogeneous reactor are typically neutron transport or diffusion codes. Examples include MCNP (Monte Carlo N-Particle), SCALE (Standardized Computer Analyses for Licensing Evaluation), and various proprietary codes developed by reactor design companies. These codes use complex algorithms to simulate neutron behavior and interactions within the reactor.
How do these codes help in reactor design and safety analysis?
These codes help in reactor design and safety analysis by providing accurate simulations of neutron behavior within the reactor. By understanding how neutrons diffuse and interact with reactor materials, engineers can optimize reactor geometry, fuel composition, and control mechanisms to ensure efficient and safe operation. They also help in predicting how the reactor will respond to various operational and accidental scenarios.
What input data is required for these codes to calculate diffusion parameters?
The input data required for these codes typically includes the reactor geometry, material compositions, temperature profiles, and initial neutron source distributions. Additionally, nuclear cross-section libraries, which provide data on the probabilities of various neutron interactions, are essential for accurate calculations.
What are the main challenges in calculating diffusion parameters for a homogeneous reactor?
The main challenges in calculating diffusion parameters for a homogeneous reactor include accurately modeling the complex interactions between neutrons and reactor materials, handling the large computational requirements for detailed simulations, and ensuring that the input data is precise and representative of actual reactor conditions. Additionally, validating the results against experimental data or other benchmark calculations is crucial for ensuring the reliability of the simulations.
  • Nuclear Engineering
