MHB Coefficient of friction and effects of
The discussion centers on calculating tire wear based on the coefficient of friction between a polyester and rubber tire and the road surface. It highlights that while static friction is independent of weight, wear occurs due to slippage, which complicates calculations. Theoretical analysis of this wear is deemed complex, as it would require accounting for various factors, including tire material cohesiveness. An experimental approach to measure wear is suggested as a more practical solution. Overall, understanding tire wear involves intricate relationships between friction, slippage, and material properties.
Casio1
Not a question from a college course or anything like that, but one of interest to me:)
You take a car tyre made of polyester and rubber, the treads are cut to about 7mm deep, the roads coefficient of friction are normally about 0.7 in conjunction with contact of the tyre, if the weight is independant of the static friction between the tyre and road surface, how could a calculation be performed to work out how much wear takes place when a tyre rolls along the road surface?
Mathematics news on Phys.org
If the tyre were really "rolling", there would be NO friction and so no wear. In order that there be friction, there would have to be some slippage and the friction and wear would depend on the amount of slippage which is not given here.
I think it would also depend on the material of the tire itself - its "cohesiveness". I think the formula would be immensely complicated. That is, I think a theoretical analysis would be quite complicated. An a posteriori experimental result would naturally be much easier.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
