Coefficient of friction between puck and ice
In summary, the coefficient of friction between a puck and ice is a measure of resistance that must be overcome for the puck to slide across the ice surface. It is determined through experiments and calculations using a tribometer. This coefficient can be affected by factors such as temperature, surface texture, and lubrication, and it plays a crucial role in ice hockey gameplay. Teams may adjust these factors to change the coefficient of friction for their desired gameplay.
alex kennedy
[/B]
A hockey puck travels across the ice at 6.5m/s. the puck travels a total of 7.6m. What is the coefficient of friction between the puck and the ice.
[/B]
fnet=ma
Ffr= coefficient of friction x force normal
[/B]
I found my acceleration, but I feel like I cannot get the coefficient of friction without the mass. Please help.
It can be done with the 2 equations you gave. Just substitute everything you know and see if anything cancels.
What is the normal force equal to, in this situation?
Related to Coefficient of friction between puck and ice
1. What is the coefficient of friction between a puck and ice?
The coefficient of friction between a puck and ice is a measure of the amount of resistance or force that must be overcome for the puck to slide across the ice surface. It is typically denoted by the symbol "μ" and can vary depending on factors such as the temperature and texture of the ice.
2. How is the coefficient of friction between a puck and ice determined?
The coefficient of friction between a puck and ice is determined through experiments and calculations. In a laboratory setting, a device called a tribometer is used to measure the force required to move the puck across a surface of ice at a constant speed. The ratio of the force to the weight of the puck is then used to calculate the coefficient of friction.
3. What factors affect the coefficient of friction between a puck and ice?
The coefficient of friction between a puck and ice can be affected by several factors, including the temperature and texture of the ice surface, the weight and shape of the puck, and the amount and type of lubrication present on the ice. The type of material used to make the puck can also play a role in the coefficient of friction.
4. How does the coefficient of friction between a puck and ice impact gameplay in ice hockey?
The coefficient of friction between a puck and ice is a crucial factor in ice hockey gameplay. A higher coefficient of friction means there is more resistance, making it more difficult for players to move the puck across the ice. This can affect the speed and accuracy of shots, as well as the overall pace of the game.
5. Can the coefficient of friction between a puck and ice be changed?
Yes, the coefficient of friction between a puck and ice can be changed. Factors such as temperature, surface texture, and lubrication can be adjusted to alter the coefficient of friction. In ice hockey, teams may use different types of pucks or adjust the temperature of the ice to achieve their desired level of friction for gameplay.
