Coefficient of friction/ dynamics problem
In summary, Lilly will coast to a stop after hitting the rough patch of ice with a coefficient of friction of .0800.
lah214
Lilly, whos mass is 45.0 kg, is ice skating with a constant speed of 7.00 m/s when she hits a rough patch of ice with a coefficient of friction of 0.0800. How long will it take before Lilly coasts to a stop?
m=45 kg
v=7m/s
coefficient of friction=.08
equation 1: f=(coefficient of friction) x Normal Force
equation 2: v=u+at
I know that the force of friction is 35.2 N. I got this by using equation 1.
I know that Lilly is no longer going at a constant speed once she hits the rough patch of ice, so I know she is not in equilibrium, and therefore there must be some acceleration. In order to find the acceleration though, I must know the net force. I'm having trouble figuring out how to find that.
Can anyone please give me a hint on how to find the net force? Thanks in advance if you can!
If you've found the friction, you've found the net force in the horizontal direction. Keep in mind that the frictional force points opposite to the motion of the skater, and therefore the skater will have a constant deceleration. You know that fk = ma by Newton's Second Law, now you can find the deceleration. Does that help?
ahh! yes, thank you soo much! I always forget that the net force is just friction, because it seems weird that's its going in the opposite direction as the net force. Thank you soo much!
it being the skater
You're welcome. Just to make sure you have a handle on what's going on, remember that the net force is equal to ma. We juse happened to encounter a case where the friction was the only force acting in the horizontal direction. If someone was pushing the skater at the same time, we'd have to account for the friction and the pushing force in the net force equation.
Oh, yeah, that's actually what we've been doing in my class lately: the pushing at the same time. It had been some time since we had a problem where the only force was friction, hah, and I spent like 20 minutes trying to figure out how to do it. Anyway, thanks for all the help, I really appreciate it!
Related to Coefficient of friction/ dynamics problem
1. What is the coefficient of friction?
The coefficient of friction is a measurement of the amount of resistance between two surfaces when one surface moves over the other. It is represented by the symbol "µ" and is a dimensionless quantity.
2. How is the coefficient of friction calculated?
The coefficient of friction is calculated by dividing the force of friction between the two surfaces by the normal force acting between them. This can be represented as µ = F/N, where F is the force of friction and N is the normal force.
3. What factors affect the coefficient of friction?
The coefficient of friction can be affected by factors such as the type of surface, the roughness of the surfaces, the weight or mass of the objects, and the presence of any lubricants or contaminants on the surfaces.
4. How does the coefficient of friction impact the motion of objects?
The coefficient of friction plays a significant role in determining the motion of objects. A higher coefficient of friction means there is more resistance between the surfaces, resulting in slower or more difficult movement. A lower coefficient of friction means there is less resistance, resulting in smoother and easier movement.
5. How do you use the coefficient of friction in dynamics problems?
The coefficient of friction is an important factor in solving dynamics problems involving motion and forces. It can be used to calculate the force of friction acting on an object, determine the minimum force needed to overcome friction and move an object, and predict the acceleration and motion of an object on an inclined surface.
