Coefficient of Friction formula
In summary: The coefficient of friction is a unitless number that is used to calculate the frictional force between two materials. The higher the coefficient of friction, the higher the frictional force will be. Coefficients of friction are often unique between different materials, and are important in many applications.
zmike
139
I am trying to do some coefficient of friction questions but I am very confused with this concept. I don't understand the purpose of finding the coefficient of friction (is there an anology that can help me understand it?)?
and
I am unsure of the units to use for the result of the formula Ff/N (shouldn't it be in Newtons but doesn't Newtons cancel out when you divide the two forces?)?
thanks
Perhaps you could list a problem that you are having trouble with and explain what you don't understand.
The frictional force is calculated by F = (mu)*N where mu is the coefficient of friction (either kinetic or static depending on the situation) and N is the normal force. Coefficients of friction are unitless and N is already in Newtons so the units work out. The higher the coefficient of friction is the higher the frictional force will be (if N remains constant). The coefficient of friction is usually unique between two different materials (rubber on cement, ice on ice, wood on rubber, etc). Why is coefficient of friction important? Well, if you were an engineer working for a tire company you would probably want to experiment with different materials that gave you the highest coefficient of friction against snow/pavement/mud so that you could find the safest tire. There are many applications for where coefficients of friction would be important.
Theses were the 2 problems, I had problems with.
1. Determine the coefficient of friction. It takes 59 N to move a 22 kg leather case (static friction).
Since normal force is = gravity force, 22*9.81=215.82 N
Ff=215.82 N *u - I got stuck here
2. Determine the magnitude of Fk of the average acceleration and stopping distance during the skid of a car (values know below).
V1= 26.8m/s
V2=0
Distance= 39.3 m
mass=1580
u=1.07
I got the acceleration of 9.14 m/s^2 then I got the average stopping force with the friction formula and got 1.44 x 10^4 but I don't know what to do from here.
thanks again
I solved the 1st one but I still can't figure out 2.
V1= 26.8m/s
V2=0
Distance= 39.3 m
mass=1580
u=1.07
re part 2)
the 9.14 looks good. The frictional force is as you posted above:
1580*g*1.07
But how do I find out the stopping distance during the skid of a car. The distance I have is before the car skids.
zmike said:
For question number 1, why is 59 N the net force. Should 59 N be the applied force since it says "it takes to 59 N to move..."
So shouldn't it be Fnet= Fapp-Ff?
This doesn't make sense, how do I determine whether it means net force or applied?
thanks
It's not. Since it's a stationary (non-moving) object, according to Newton your Net Force is going to be 0.
the way these types of problems are worded is that the applied force, that just sufficient to make it to move, is equal to the frictional force. Other problems that specify an acceleration, displatement, etc are done by Newtons second usu using kinetic coefficient.. In this case the static friction is given so you want to apply just enuf force to overcome the frictional resistance.
ma=Fapp-Ff=0.
59=9.8*22*mu
mu=?
FAQ: Coefficient of Friction formula
What is the coefficient of friction formula?
The coefficient of friction formula is a mathematical expression that calculates the amount of friction between two surfaces in contact with each other. It is represented as μ = F/N, where μ is the coefficient of friction, F is the force of friction, and N is the normal force.
How is the coefficient of friction formula used in real life?
The coefficient of friction formula is used in various fields, such as engineering, physics, and materials science, to understand and predict the behavior of objects and surfaces in contact. It is used to design and improve products, determine the maximum load a surface can withstand, and calculate the required force to move an object.
What factors affect the coefficient of friction?
The coefficient of friction is affected by the nature of the two surfaces in contact, the roughness of the surfaces, the normal force between them, and the presence of any lubricants. Additionally, temperature, humidity, and surface finish can also influence the coefficient of friction.
Can the coefficient of friction be negative?
No, the coefficient of friction cannot be negative. It is always a positive value or zero. A negative value would imply that the force of friction is acting in the opposite direction of the applied force, which is not possible.
How is the coefficient of friction related to the angle of incline?
The coefficient of friction is related to the angle of incline through the sine of the angle. It can be calculated by dividing the coefficient of friction by the cosine of the angle. As the angle of incline increases, the coefficient of friction also increases, making it more difficult for an object to slide or roll down the incline.
