Coefficient of Friction problem
In summary, this conversation discusses a problem involving a man sliding down a 20m long waterslide at an angle of 34 degrees above the horizontal. The slide ends in a ramp at a 45 degree angle, and the man lands in a pool at the end. However, due to a water conservation decision, the last 5m of the slide is no longer frictionless and the man flies off the ramp, missing the pool and landing on the pavement 12m away. The conversation then discusses the use of Newton's second law and a free body diagram to solve for the coefficient of friction between the man and the slide. The solution involves calculating the horizontal and vertical components of the man's speed, and then determining the energy lost
tbone413
An attraction at a waterpark includes a straight waterslide 20m long at an angle of 34 degrees above the horizontal. The waterslide ends in a ramp 5 m long at an angle of 45 degrees above the horizontal. People sliding down the slide land in a small pool just past the end of the ramp. The waterslide is kept frictionless by spraying fine streams of water onto it through several nozzles located along the length of the slide.
Unfortunately, a poor management decision to conserve water at the water park results in the water being turned off just as a 120 kg man enters the ramp, so that the last 5m of his trip on the slide is no longer frictionless. The man flies off the ramp, misses the pool and lands on the pavement a horizontal distance of 12m fro the end of the slide. What is the coefficient of friction between the man and the waterslide?
F(x) = -Fk = ma(x)
F(y) = n - mg = 0
n-mgcos(theta) = 0
Ff(force of friction) + mgsin(theta) = ma(up)
Well I am not really sure how to attempt this problem at all, its extra credit and we haven't quite learned this material yet. I do know though that its a Newtons second law problem and that when going up the ramp the frictional force will cause the acceleration to decrease. I also know that I have to use a FBD to figure out the acceleration and velocity of the man at the moment he hits the ramp, and then solve for the coefficient of friction. However I am not quite sure what steps to take. So if someone could maybe walk me through their thought process id Really appreciate it.
Work out the horizontal and vertical components of his speed at the start of the friction part ( using either conservation of energy or constant vertical accelearation)
Then work out what speed he must have left the ramp to reach the crash point - this is just the standard cannon ball firing question.
Then you have how much speed ( and therefore energy ) he lost to friction.
Since energy is force * distance you can work out the average force, and with his weight to give you the normal force - you have the coefficent of friction.
Im not quite sure how you would find the components of his speed using the constant vertical acceleration. can you clarify a bit more?
If you neglect friction the only forces acting are his weight, so you can calculate the vertical accelaration of an object down an inclined plane just by knowing 'g' and the angle
ahh ok. that makes sense.
I came up wth 22.1 m/s for his velocity he left the ramp at, and 11.54 m/s for his velocity before he left..which doesn't make sense.
Are either of those numbers similar to what you got?
FAQ: Coefficient of Friction problem
What is the Coefficient of Friction?
The Coefficient of Friction is a measure of the amount of resistance or force that occurs between two surfaces in contact with each other. It is a dimensionless number and is represented by the symbol μ.
How is the Coefficient of Friction calculated?
The Coefficient of Friction is calculated by dividing the force of friction by the normal force. This results in a decimal value between 0 and 1, where 0 represents no friction and 1 represents maximum friction.
What factors affect the Coefficient of Friction?
The Coefficient of Friction can be affected by various factors including the nature of the surfaces in contact, the roughness of the surfaces, the amount of force pressing the surfaces together, and the presence of any lubricants or contaminants.
How is the Coefficient of Friction used in real-world applications?
The Coefficient of Friction is used in various fields such as engineering, physics, and material science to understand the behavior of materials and surfaces in contact. It is also important in designing and improving the efficiency and safety of machines and structures.
What are some methods for reducing the Coefficient of Friction?
Some common methods for reducing the Coefficient of Friction include using lubricants, polishing or smoothing surfaces, and using materials with lower friction properties. Additionally, adjusting the force or pressure between surfaces can also affect the Coefficient of Friction.
