NoobertNoClue
- 2
A waterslide ride consists of a straight guided ramp, at an angle theta (to the horizontal plane), with a transition to a short horizontal section at the bottom of the slide (1m long), just above the surface of a splace pool of length L. Patrons queue on a platform of height h (edge of platform is 18m from start of horizontal section of slide) before climbing onto a 10kg toboggan and sliding down slide under the force of gravity until they leave the slide and skip along surface of splash pool.
Water slide is lubricated by 12L/s of water
When theta = 53degrees
h = 7.6m
1. Determine Rider speed
2. and stopping distance if;
0.2 (Q 20)/50 (Where Q is in L/s)
0.6
****Taking into account dynamic friction only*****
3. Determine length of splash pool needed L
I have been trying to figure this out using various equations, none of which seems correct... someone please help guide me onto the right track?!
I think i need to use the equation a= netforce / mass = g(sin theta - cos theta)
then use the formula V(final)^2 = V(initial)^2 + 2 as
to find net force I just used netforce= mass x g <<<<<<< I think this is incorrect because I am supposed to factor in the angle?! but how?
then use formula Stopping distance (D) = (V(final)^2 / 2x us x g) - (V(final)^2 / 2x uw x g)
i cannot figure out where to use the flow rate in this at all... i think i have totally stuffed up... i really need help
