Coefficient of restitution and velocity
In summary, the ratio of velocity of separation to the velocity of approach in a head on collision is known as the coefficient of restitution. It is possible for the velocity of separation to be larger than the velocity of approach, resulting in a coefficient of restitution greater than 1. This would imply an increase in kinetic energy and a violation of the conservation of mechanical energy. Such collisions are known as superelastic collisions.
Parikshit M
We know that the ratio of velocity of separation to the velocity of approach of two bodies in a head on collision is called coefficient of restitution .Is there no possibility that the velocity of separation is quite larger than that of approach? or vice versa? can't the ratio be more than 1 or less than 0 ?
Those are two very different situations. For example, if the bodies stick together (a perfectly inelastic collision) the separation velocity will be zero.
What do you think a coefficient of restitution greater than one would imply?
It would imply that the velocity of separation is greater than that of approach .
And what of the energy?
Well, yes. But what does that imply as far as energy goes?
energy increases?.. due to increase in velocity , kinetic energy increases and hence final kinetic energy will be greater.So does that mean mechanical energy is not conserved?
That's correct. A collision where the kinetic energy is greater after the collision than before would be an example of a superelastic collision--mechanical energy is not conserved. Some internal energy of the system must have been converted to mechanical kinetic energy. Not the typical collision between two objects.
Likes Parikshit M
thanks a lot my books never said anything about super elastic collisions , delighted ! thanks again
Related to Coefficient of restitution and velocity
1. What is the coefficient of restitution?
The coefficient of restitution (COR) is a dimensionless quantity that measures the elasticity of a collision between two objects. It is defined as the ratio of the relative velocities of the objects after and before the collision.
2. How is the coefficient of restitution calculated?
The coefficient of restitution can be calculated by dividing the relative velocity of the objects after the collision by the relative velocity before the collision. It can also be determined by measuring the heights of the objects before and after the collision, using the equation COR = √(h₂/h₁), where h₂ is the height of the object after the collision and h₁ is the height of the object before the collision.
3. What is the relationship between the coefficient of restitution and velocity?
The coefficient of restitution and velocity have an inverse relationship. This means that as the COR increases, the relative velocity of the objects after the collision decreases. In other words, a higher COR indicates a more elastic collision, where less kinetic energy is lost to deformation and heat.
4. What factors affect the coefficient of restitution?
The coefficient of restitution is affected by the materials and surface properties of the objects involved in the collision. It also depends on the angle and speed at which the objects collide, as well as the temperature and air resistance. In general, a higher COR is observed in collisions between smooth, rigid objects with no energy loss due to deformation or friction.
5. Why is the coefficient of restitution important?
The coefficient of restitution is important because it helps us understand the behavior of objects during collisions. It is used in various fields such as sports, engineering, and physics to analyze and improve the performance of equipment and structures. It also helps us understand the conservation of energy and momentum in collisions and can be used to predict the outcomes of collisions in different scenarios.
