Coefficient of Sliding Friction
In summary: Just one last golf cart question.In summary, Ms. Boylan's 1750-kg cart is traveling at a constant speed of 8.5-m/s on a wet, straight, and slippery road. A mindless student steps out in from of the cart. The wheels lock and she begins skidding and slides to a halt in 12.0-m. The coefficient of sliding friction between the tires and the slippery road is -3.01 m/s^2.
camjam73
Golf Cart Questions
Ms. Boylan on her 1750-kg cart is traveling at a constant speed of 8.5-m/s on a wet, straight, and slippery road. A mindless student steps out in from of the cart. The wheels lock and she begins skidding and slides to a halt in 12.0-m. What is the coefficient of sliding friction between the tires and the slippery road?
vf^2 = vi^2 + 2ad
a = (Fapplied - Fopposed) / mass
u = Ffriction / weight
Her acceleration is found with:
(0)^2 = (8.5)^2 + 2(a)(12)
a = -3.01 m/s^2
So, -3.01 equals applied force minus Ffriction over 1750.
Then I get stuck. If I could just figure that out, I could divide it by (1750 * 9.80) to get the coefficient. Thanks for your help.
There is no force applied.
Initially, she is going at constant speed so the forces are balanced. Force net = 0.
Afterwards, she is skidding so the only force acting when she is slowing down is the force of friction.
Ff=ma
And you know from here on. :)
Thanks a bunch! Just one other golf cart question (not friction related).
Two campus supervisors in golf carts approach each other, one from the east (Cart A) and the other from the south (Cart B). Cart A has a mass of 1750-kg and cart B has a mass of 1275-kg and is traveling at 6.7056 meters per second. They collide, become locked, and move together at an angle of 30.0 degrees. What was the speed of cart A?
(m1)(v1) + (m2)(v2) = (m1+m2)(v)
(1750)(v1) + (1275)(6.7056) = (3025)(v)
I'm stuck here trying to solve for v1. I obviously need to find the velocity of the combined mass, but I'm not sure how to use 30 degrees.
Momentum is a vector, not a scalar. It also has direction.
P1 + p2 = pf
f=final
This only works as a vector sum and if the collision is in one dimension. Your collision is in two dimensions. So in two dimensions, if you draw a diagram, you have that p1 + p2 = pf (as vectors).
You then have a right angle triangle with the hypotenuse pf and the other two sides are p1 and p2.
p1^2 + p2^2 = pf^2
You also know the angle, which can help you determine another relationship.
Oh, so it's just 6.7 tan 30 = 3.87 ?
Well actually I don't know. It doesn't say if the angle of 30 is formed with the horizontal or with the vertical. But that's how you would do it. I just don't know where the 30 degree angle is.
Thanks for your help, Husky.
Related to Coefficient of Sliding Friction
1. What is the coefficient of sliding friction?
The coefficient of sliding friction is a measure of the amount of resistance between two surfaces when one surface is sliding or moving across the other.
2. How is the coefficient of sliding friction calculated?
The coefficient of sliding friction is calculated by dividing the force required to slide an object across a surface by the weight of the object.
3. What factors affect the coefficient of sliding friction?
The coefficient of sliding friction can be affected by factors such as the type of surface materials, the roughness of the surfaces, the amount of force applied, and the presence of lubricants.
4. Why is the coefficient of sliding friction important?
The coefficient of sliding friction is important in understanding and predicting the behavior of objects in motion. It is also crucial in designing and improving machines and structures that rely on sliding or rolling motion.
5. How can the coefficient of sliding friction be reduced?
The coefficient of sliding friction can be reduced by using lubricants, polishing or smoothing the surfaces, or by using materials with lower coefficients of friction. Additionally, reducing the force or weight applied can also decrease the coefficient of sliding friction.
