Coefficients in the linear combination of a k-form
In summary: Differential forms are linear transformations between vector spaces- The exterior derivative is a linear operation between vector spaces- The exterior derivative of a function is the derivative of the function at a point where the function has an infinitesimal change of coordinates- The exterior derivative is a linear operation between vector spaces, and it can be decomposed into the product of a linear operator and a vector- The exterior derivative is a vector, and it has a gradient
Maxi1995
Hello,
We defined a k-form on a smooth manifold M as a transfromation
Where the right space is the one of the alternating k-linear forms over the tangent space in p.
If we suppose we know, that we get a basis of this space by using the wedge-product and a basis of the dual space, then we might get for a given form:
Can someone explain to me what the coefficient in this linear combination is? I know that they are functions and in some cases scalars. But I don't know the cases. According to the definition at the beginning I suppose, that they are funtions for a given p and become scalars if we have argument values of the tangent space. Is this correct?
Greetings
Maxi
You have ##\omega \in \Lambda^k TM## which is a vector space with basis vectors ##dx^{i_1}\wedge \ldots \wedge dx^{i_k}##. Thus the ##\omega_{i_1 \ldots i_k}## are scalars, the coefficients in the linear combination which represents ##\omega ## according to this basis.
The evaluation ##p \longmapsto \omega_p## at a certain point affects only the differential forms, resp. the function those forms apply to, not the scalar coefficients.
E.g. if ##k=1## and ##\omega = 2dx## we get ##p \longmapsto \omega_p = (f \longmapsto 2df_p)## or ##f(p+v)=f(p)+df_p\cdot v + o(v)=f(p)+\frac{1}{2}\omega_p(f)\cdot v+o(v)##. The coefficient is not affected.
What fresh says is of course exactly right, but in one special case, you can say more about these coefficients. if you have a set of k one- forms, each written in terms of the n basic one forms dx1,...,dxn, then each of your one - forms needs n coefficients. If you wedge together those k one - forms, you get a k-form expressible in terms of the standard coordinate k-forms, as you have written, with some coefficients you have asked about. Those cofficients in this case are exactly all k by k sub determinants of the n by k matrix of coefficients you began with, the ones expressing the k arbitrary one - forms in terms of the n standard coordinate one-forms. Note there are exactly "n choose k" such k by k subdeterminants.
Indeed if you prove independently that the space of n-forms (at one point) is one dimensional, then one way to define the determinant of a matrix is as the coefficient needed to write the wedge product of its rows in terms of the standard n-form. More abstractly, a linear endomorphism of an n dimensional vector space induces a linear endomorphism of its space of n-linear alternating functions, which must be multiplication by a scalar, which scalar is then defined as the determinant of the original endomorphism.
Hello,
thank you for your answer.
@ fresh_42
What is f in your notation? Is it a curve?
I understand what you said about the elements of the basis, thus to say that they are just scalars. But I found in a Wikipedia article (https://en.wikipedia.org/wiki/Differential_form#Differential_calculus) that we might find a linear combination where these factors are smooth functions from $$U \subset \mathbb{R}^n \rightarrow \mathbb{R}$$. Because of this I'm going to add more detail the context in which my question arose.
We defined the outer derivative on $$ \mathbb{R}^n$$ as follows: Let $$w$$ be a k-form on a open set U
Then we define the exteriour derivative by
where
is the (normal) differential of the function $$w_{i_1 \cdots i_k}$$ (Please note that we used here the Einstein notation, so we have a sum over j.).
As you said I expected to be the coefficients scalars, but in this case they are just smooth functions, what puzzled me. Can you explain that to me?
@mathwonk
We had the following:
Where $$V^*$$ is the dual space and j counts the lines and i the columns. What do you mean by subdeterminants?
Best wishes
Maxi
A smooth function the differential form ##\omega ## applies to, so in general no curve, simply a variable.
The moment you write ##d\omega## you do no longer consider a certain and thus fixed vector in ##\Lambda^k## but investigate what happens by infinitesimal changes of coordinates. You switch from ## \vec{v}=v_0\vec{e}_0## to ##\vec{v}(t)=v_0(t)\vec{e}_0##. It is literally the transition from algebra to calculus. Of course now you will have to say in which way these coordinates totter, i.e. what is ##t \mapsto v_0(t)## or in general and local coordinates again, what is ##d\omega_{i_1\ldots i_k} = \sum_{j}\dfrac{\partial \omega_{i_1\ldots i_k}}{\partial x^j}dx^j\,.##
If you want to know, why this might confusing you, have a look at the 10 items list at the end of section 1 herein:
https://www.physicsforums.com/insights/journey-manifold-su2mathbbc-part/
I'm not sure whether it will confuses you further or actually be of help, but at least it might serve as a quick reference guide (5 parts):
https://www.physicsforums.com/insights/the-pantheon-of-derivatives-i/
Hello,
thank you for your answer, I'm going to read through these pages. I'll give a sign in case of further questions.
Hello,
I have another question in this context. Let us say we want to talk about the function as object, thus to say the function itself as element of $$\Lambda ^k V.$$ We derived the coefficients in our proofs by using the smooth k-form itself. We set the coefficients as $$w_{i_1...i_k}=w(e_{i_1},...,e_{i_k})$$. From this and the fact that we made other proofs in $$\Lambda^n V$$ where V was n-dimensional and $$w$$ had the form $$w= f dx_1\wedge...\wedge dx_n$$ with f a smooth function from $$U \subset \mathbb{R}^n \rightarrow \mathbb{R}.$$ I'm still a little bit puzzled, but think this might be caused by vieweing the function as object. Is that right?
Related to Coefficients in the linear combination of a k-form
1. What is a coefficient in the linear combination of a k-form?
A coefficient in the linear combination of a k-form is a numerical value that is multiplied by a k-form to create a linear combination. It represents the weight or magnitude of the k-form in the combination.
2. How is a coefficient determined in the linear combination of a k-form?
The coefficient in the linear combination of a k-form is typically determined through a process of solving a system of equations. This involves manipulating the equations to isolate the coefficient and finding its value through substitution or elimination.
3. What is the significance of coefficients in the linear combination of a k-form?
Coefficients in the linear combination of a k-form are significant because they allow for the representation of complex mathematical expressions in a simpler form. They also help to determine the contribution of each k-form in the linear combination.
4. Can coefficients in the linear combination of a k-form be negative?
Yes, coefficients in the linear combination of a k-form can be negative. This means that the k-form is being subtracted rather than added in the linear combination. Negative coefficients can have a significant impact on the overall value of the linear combination.
5. How do coefficients in the linear combination of a k-form relate to vector operations?
Coefficients in the linear combination of a k-form are closely related to vector operations. This is because k-forms can be viewed as multilinear maps that take in vectors as inputs and produce a scalar as an output. The coefficients represent the contribution of each vector in the linear combination to the overall scalar output.
  • Differential Geometry
  • Linear and Abstract Algebra
