Coffee cup, bomb calorimeter: Open, closed, or isolated?
In summary, a coffee cup is not considered a closed system because it is constantly exchanging matter and energy with its surroundings, such as the steam and heat evaporating from the coffee. A bomb calorimeter, on the other hand, is an isolated system because it does not exchange matter or energy with its surroundings. The water inside the bomb calorimeter is considered part of the surroundings since it is not involved in the chemical reaction that is being measured.
gauss44
49
Is a coffee cup usually considered to be a closed system? Why or why not? Does it matter that steam or hot coffee may be evaporating? (I think the steam is usually considered to be an insignificant amount of matter, allowing classification to be a closed system, but am unsure.)
Is a bomb calorimeter an isolated system? Why or why not? Is the water inside of a bomb calorimeter generally considered to be part of the "surroundings?" (I think not, just checking.)
(I tried looking this up online and cannot find any definitive answer or actual examples that were adequately helpful.)
This has the sound of homework: state the definitions/properties of open, closed, and isolated systems; apply those definitions/properties to the systems you've described.
gauss44 said:
I guess you could project that onto any question in this forum. I sense a troll at work.
It's a very common pre-lab quiz question intended to determine whether you know the definitions of open, closed, and isolated systems.
If you don't know the definitions/properties/differences of open, close, and isolated systems, this turns into an endless game of "Well if that's "blank," then what's this?"
State them, apply them to each, and I'll be more than happy to tell you whether you've done so correctly, or explain to you where you've done so incorrectly, and what is incorrect.
If a coffee cup is a closed system, how are you supposed to drink the coffee? You don't need to go online to find the answer to this question.
Likes Bystander
I can provide a response to this question. A coffee cup can be considered a closed system because it is not exchanging matter with its surroundings. However, it is not a perfectly closed system because steam or hot coffee may be evaporating from the cup, which would result in a small amount of matter leaving the system. This may not significantly impact the overall classification of the system, but it is important to consider when conducting experiments.
On the other hand, a bomb calorimeter is typically considered an isolated system because it is designed to prevent any matter from entering or leaving the system. This is important for accurately measuring the heat released during a chemical reaction. The water inside the bomb calorimeter is generally considered part of the surroundings, as it is not involved in the reaction and is used to absorb the heat released.
It is worth noting that the classifications of open, closed, and isolated systems are not always black and white. In some cases, a system may have characteristics of more than one classification. It is important for scientists to carefully consider the properties of a system when conducting experiments and interpreting results.
Related to Coffee cup, bomb calorimeter: Open, closed, or isolated?
1. What is a bomb calorimeter?
A bomb calorimeter is a scientific instrument used to measure the heat energy released during a chemical reaction, typically in the form of combustion. It consists of a sealed container, known as a bomb, surrounded by water and an insulated jacket. The reaction takes place inside the bomb, and the resulting heat is absorbed by the surrounding water, allowing for accurate measurement of the heat of the reaction.
2. What is the purpose of a bomb calorimeter?
The purpose of a bomb calorimeter is to determine the caloric content of a substance by measuring the heat energy released during a chemical reaction. This is useful for studying the energy content of different foods, fuels, and other substances, as well as for conducting research on chemical reactions and thermodynamics.
3. What is the difference between an open, closed, and isolated bomb calorimeter?
An open bomb calorimeter allows for heat to freely enter or escape the system, whereas a closed bomb calorimeter is insulated and does not allow for heat exchange with the surroundings. An isolated bomb calorimeter is completely sealed and insulated, preventing any heat transfer with the surroundings. The type of bomb calorimeter used depends on the specific experimental conditions and the accuracy required for the measurement.
4. How does a bomb calorimeter work?
A bomb calorimeter works by igniting a sample of the substance being studied inside the bomb, causing it to undergo a chemical reaction. As the reaction takes place, the heat is transferred to the surrounding water and the change in temperature is measured. This change in temperature, along with other factors such as the mass of the sample and the heat capacity of the water, can be used to calculate the caloric content of the substance.
5. What are some potential sources of error in a bomb calorimeter experiment?
Some potential sources of error in a bomb calorimeter experiment include heat losses to the surroundings, incomplete combustion of the sample, and heat losses due to stirring or other mechanical processes. It is important for scientists to carefully control and account for these potential sources of error in order to obtain accurate results.
  • Classical Physics
  • Other Physics Topics
  • Quantum Interpretations and Foundations
  • Materials and Chemical Engineering
  • Classical Physics
26K
