Coherent states: Orthonormal set? Overcomplete basis?
In summary, coherent states |α⟩ and |β⟩ can exist simultaneously with a nonzero probability due to their closure relation, and they form an overcomplete basis in which any state can be decomposed. This is important for the Sudarshan-Glauber P representation. An overcomplete basis means that it has more vectors than needed to span the required subspace of the Hilbert space, and in the case of coherent states, this is due to their dependence on continuum parameters. This is similar to an overdetermined linear system of equations.
LagrangeEuler
717
For two different coherent states
[tex]\langle \alpha|\beta \rangle=e^{-\frac{|\alpha|^2+|\beta|^2}{2}}e^{\alpha^* \beta}[/tex]
In wikipedia is stated
https://en.wikipedia.org/wiki/Coherent_state"Thus, if the oscillator is in the quantum state | α ⟩ {\displaystyle |\alpha \rangle } |\alpha \rangle it is also with nonzero probability in the other quantum state | β ⟩ {\displaystyle |\beta \rangle } |\beta \rangle (but the farther apart the states are situated in phase space, the lower the probability is). However, since they obey a closure relation, any state can be decomposed on the set of coherent states. They hence form an overcomplete basis, in which one can diagonally decompose any state. This is the premise for the Sudarshan-Glauber P representation. "
Could you please explain me what is OVERCOMPLETE BASIS?Also, when some authors write ## \langle \alpha|\beta \rangle \neq \delta(\alpha-\beta)## is ##\delta(\alpha-\beta)## Dirac ##\delta## or some type of continuous Kronecker?
It's a Dirac ##\delta##. An overcomplete basis means that it has more vectors than needed to span the required subspace of the Hilbert space where the vectors like ##\left|\alpha\right.\rangle## exist. If it's said to be an overcomplete basis of the whole ##\mathcal{H}##, then it means that it's a basis and it should contain vectors that are not all orthogonal with every other basis vector (therefore not a linearly independent set).
You can compare this to the concept of an overdetermined linear system of equations:
https://en.wikipedia.org/wiki/Overdetermined_system
Edit: And it's quite obvious that the set of all generalized Gaussians
##\displaystyle\psi (x) = Ae^{-kx^2 + bx + c}##,
with ##b## and ##c## complex numbers, is an overcomplete basis because it depends on continuum parameters while all normalizable states of the 1D harmonic oscillator can be spanned by a discrete basis. An example of that kind of discrete basis is the set of all eigenstates of the Hamiltonian
##\displaystyle\hat{H} = \frac{1}{2m}\hat{p}^2 + \frac{1}{2}m\omega^2 \hat{x}^2##.
Likes LagrangeEuler and vanhees71
Related to Coherent states: Orthonormal set? Overcomplete basis?
1. What are coherent states?
Coherent states are a type of quantum state that possess some properties of classical waves, such as a well-defined amplitude and phase. They are often used to describe the behavior of quantum systems that exhibit classical-like behavior.
2. How are coherent states related to the concept of orthonormal set?
Coherent states form an orthonormal set, meaning that they are mutually orthogonal and have a unit norm. This allows them to be used as a basis for representing other states in a quantum system.
3. What is an overcomplete basis?
An overcomplete basis is a set of vectors that is larger than the dimension of the vector space it is spanning. In the case of coherent states, the set is overcomplete because there are an infinite number of them, even though they still form a complete basis.
4. How are coherent states used in quantum mechanics?
Coherent states are used in quantum mechanics to describe the behavior of quantum systems in terms of classical-like properties, such as position and momentum. They are also useful for calculating transition probabilities and studying the dynamics of quantum systems.
5. What are the advantages of using coherent states as a basis?
Coherent states have several advantages as a basis in quantum mechanics. They have a simple mathematical form, making calculations easier. They also have a well-defined classical limit, which allows for a better understanding of the classical behavior of quantum systems. Additionally, they can be used to construct other important states, such as squeezed states and Fock states.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
