FusionJim
- 21
- 11
Assume i want to create a magnetic circuit within a ferrite core with airgap (i need the B field in airgap). The ferite core would have a coil on it. Problem is if i want my core airgap area and magnetic path length longer than wavelenght of current through the coil i would have high losses as it would radiate. Can i solve this issue with using coax to wind the coil? Is the coil the main problem that radiates or is it also the B field in the core? I guess i'm asking does the core also have to conform to wavelenght constraints or just the coil?
Ps. Also what happens in the simpler case without a core, just a coax wrapped to form an air core coil, can such coax coil size be greater than wavelenght and still result in homogenous B field in the coil inner volume?
