I Coin tosses, values, and what I'm missing
  • I
  • Thread starter Thread starter member 428835
The discussion revolves around the expected number of sequences of HHH in coin tosses and the confusion regarding the relationship between average tosses and the number of sequences. It is established that on average, it takes 14 tosses to get the first HHH sequence, but the expected number of HHH sequences in 14 tosses is calculated to be 1.5, leading to confusion. The key point is the independence of trials; the game structure affects the probability of obtaining multiple HHH sequences. When starting from a random point, the expected outcomes differ due to the nature of the sequences and their dependencies. Understanding these concepts clarifies the apparent discrepancies in expected values.
member 428835
Suppose we toss a coin until we get HHH. On average this will take 14 tosses.
Now how many sequences of HHH would we get if we tossed the coin 14 times? We have 3 sequence positions and 14 units available, meaning we have 14-3+1 = 12 sequence positions available. Each position has 0.5 odds of being heads. So we have ##12*0.5^3 = 1.5 \neq 1##. I'm wondering why these two numbers aren't the same. I'm definitely misunderstanding something here.
As a follow up, so we know it takes 14 tosses on average to get HHH. So if we play a game where you pay 1$ per coin toss, then for the game to be fair if you made HHH you would receive 14 dollars (after you make HHH the game restarts, so you can't let it ride). But now suppose I charge you 10$ for a 10 toss game and give you 10$ if you make HHH, and if you do the game ends. It seems to me the expected number of HHH sequences given 10 tosses is now ##(10-2)0.5^3=1##, so I'm pretty confused. Any help?
When we repeat sets of 14 tosses, the average of NNN counts is 1.5. When we repeat tosses until we get first NNN sequence, the average toss times is 14. I think we can distinguish them.
The main thing you are missing is independence. As long as the trials are independent the numbers should agree. For example, if you organise the game into separate sets of three tosses, then you have standard binomial trials with ##p = \frac 1 8##.
In the game you describe the trials are not independent. Once you get the first sequence of HHH you have a 50-50 chance of getting another one on the next turn. The sequences of HHH tend to clump together: you have a longish waiting time for the first one (or after a T), then often two or more together.
Note that for the expected time to get HHH you are always starting the game from scratch (effectively a T on a zeroth toss). Whereas, if you start from a random point in a sequence, then you may be starting with H or HH.
Again, the expected number would only be 1 in 10 tosses starting from a random point in the sequence. The game effectively starts with the zeroth toss being a T (which is the worst possible starting point).
Likes member 428835
PS to take an illustrative example. Suppose we have a strict sequence of failures followed by two successes repeated. The game always looks like FFFFFFFFSSFFFFFFFFSS ...
The expected number of successes in a random selection of 10 trials is 2. And, if we start at a random point in the sequence, then the probability the next trial is a success is ##0.2##. But, at the start of the game we always take 9 trials to get a success.
Likes member 428835
Makes tons of sense, thanks!
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
