Cold or warm dark matter or a mixture
In summary, the paper discusses the possibility of non-cold or non-collisionless dark matter as a potential solution to the discrepancy between the observed and theoretical abundance of dwarf galaxies. It explores warm, mixed, and self-interacting dark matter scenarios and their effects on the abundance of galaxies and the observed relation between HI line-width and maximum circular velocity. Ultimately, more evidence is needed to definitively rule out cold dark matter and support alternative theories.
wolram
Dearly Missed
4,446
558
This paper favors a mixture, but there are many papers that predict Cold dark matter, is there a particle that can be ruled out, or pushed to the back of favored particles.
arXiv:1611.09362 [pdf, other]
Hints against the cold and collisionless nature of dark matter from the galaxy velocity function
Aurel Schneider, Sebastian Trujillo-Gomez, Emmanouil Papastergis, Darren S. Reed, George Lake
Comments: 17 pages, 10 figures, comments welcome
Subjects: Cosmology and Nongalactic Astrophysics (astro-ph.CO); High Energy Physics - Phenomenology (hep-ph)
The observed number of dwarf galaxies as a function of rotation velocity is significantly smaller than predicted by the ΛCDM model. This discrepancy cannot be simply solved by assuming strong baryonic processes, since they would violate the observed relation between maximum circular velocity (vmax) and baryon mass of galaxies. A speculative but tantalising possibility is that the mismatch between observation and theory points towards the existence of non-cold or non-collisionless dark matter (DM). In this paper, we investigate the effects of warm, mixed (i.e warm plus cold), and self-interacting DM scenarios on the abundance of dwarf galaxies and the relation between observed HI line-width and maximum circular velocity. Both effects have the potential to alleviate the apparent mismatch between the observed and theoretical abundance of galaxies as a function of vmax. For the case of warm and mixed DM, we show that the discrepancy disappears, even for luke-warm models that evade stringent bounds from the Lyman-α forest. Self-interacting DM scenarios can also provide a solution as long as they lead to extended (≳1.5 kpc) dark matter cores in the density profiles of dwarf galaxies. Only models with velocity-dependent cross sections can yield such cores without violating other observational constraints at larger scales.
Space news on Phys.org
As far as I'm aware, there isn't anything definitive that points to cold dark matter specifically. Hot dark matter is ruled out pretty conclusively, but those observations only place an upper limit on the dark matter temperature.
From a model selection standpoint, warm dark matter is very exciting because it should be at least a little bit easier to measure its properties. But the kind of measurements described in the paper above are very difficult, and it's not easy at all to show conclusively that the problem isn't some other effect. So what we would need, as with most things in physics, is an independent check that uses a different type of observational evidence to get at the temperature of the dark matter. Direct detection of the particles would be ideal, but that may take a long time (if ever).
Likes wolram
Related to Cold or warm dark matter or a mixture
1. What is dark matter and how is it different from regular matter?
Dark matter is a type of matter that does not emit or interact with light or other forms of electromagnetic radiation. It is different from regular matter because it does not consist of atoms and does not interact with the forces that govern regular matter, such as electromagnetism and the strong and weak nuclear forces.
2. What is cold dark matter and how does it differ from warm dark matter?
Cold dark matter is a type of dark matter that moves slowly and gravitationally clumps together. It is thought to make up the majority of dark matter in the universe. Warm dark matter, on the other hand, moves faster and does not clump together as much. It is less abundant than cold dark matter.
3. Is there any evidence for the existence of dark matter?
Yes, there is strong evidence for the existence of dark matter. One of the key pieces of evidence is the observation of the rotational speeds of galaxies, which cannot be explained by the visible matter alone. Additionally, the gravitational lensing of light from distant galaxies also supports the existence of dark matter.
4. Can dark matter be created or destroyed?
Dark matter cannot be created or destroyed, as it is a fundamental component of the universe. It can only change forms or be converted into other types of matter through interactions with regular matter.
5. Could dark matter be a mixture of different types of particles?
It is possible that dark matter is a mixture of different types of particles. Some theories propose that dark matter is made up of multiple types of particles, such as WIMPs (weakly interacting massive particles) and axions. However, more research and evidence are needed to confirm this theory.
  • Cosmology
  • Cosmology
