Cold Welding: Can Asteroids Fuse?
In summary, the article says that if two asteroids come into contact with each other in space, they will fuse. It is a very rare event, and requires a lot of heat and gravity.
lilythmagebor
"Cold welding" question
My husband posed an interesting question to me that I can't rightly answer, not being any kind of expert, when I told him about the fact that metals fuse if they come into contact with one another in space.
If an asteroid collides with another asteroid, will the two fuse? If that asteroid happens to pass through the tail of a comet, will it then be incapable of fusing? (I read that if you take a metal object from Earth to space that it will not fuse with another metal because the oxidation layer remains in tact.)
I know these are all very rare circumstances. I just thought the question was interesting, and was surprised to find no information (with a somewhat cursory Google search) about any asteroids having ever fused with another.
Astronomy news on Phys.org
They actually don't, at least not under normal conditions. A cold weld--which is what this phenomenon is called--occurs when two components that fit perfectly come into contact. If you take two ridiculously flat pieces of metal, clean both so that they're absolutely free of any oxidation, and bring them together in vacuum, a cold weld will occur. Two arbitrary metal objects won't weld because, even if they appear smooth to the naked eye, they'll likely be very different on the molecular scale.
Basically, for a fusion to occur, their gravity has to hold them together. But gravity is extraordinarily weak, so the pieces have to approach extremely extremely slowly, or one of the objects has to be big enough to keep most of the ejected material from escaping (which is pretty darned big). Even then, however, they won't have fused: they'll just be a collection of rocks moving together through space. It is only if the combined gravity is large enough that the pressure and temperature allow them to fuse that they actually do. And that requires quite a lot of mass.
Even trace amounts of surface contaminants inhibit cold fusion.
Sorry, I wasn't trying to say anything opposed to ideasrule's post (if you were responding to me). I was just trying to describe what actually happens. I suppose I misused the word "fusion" in the first sentence. But I believe the rest is accurate.
Cold fusion can be a problem when working with gage blocks (also known as Johansson blocks or "Jo-blocks" for short). These are precise blocks of varying thickness made from tool or stainless steel (usually) that can be stacked together to create an exact reference for dimensional measurement. Their surfaces are polished smooth and flat. Simply pressing and twisting two or more blocks together by hand (a process called 'wringing') is sufficient to make a stable stack that resists gravitational forces (a properly wrung stack can be held sideways at one end!). No vacuum or magnetism is required.
Left wrung together for a period of time (weeks?), the blocks will permanently fuse together, rendering them useless for their intended purpose. The mechanism by which this happens is poorly understood.
Fusing two asteroids together would likely require an inelastic collision and a lot of heat: a very, very low probability event.
Thanks for answering my questions, all. Seems like this is just another one of those science facts that, while a fact, gets exaggerated. The article made it seem like any metal would fuse in a vacuum if it didn't have that layer of oxidation.
(I first read the fact here: http://goo.gl/UV1TA , and decided to look into it further here: http://goo.gl/JcH3u .)
Related to Cold Welding: Can Asteroids Fuse?
1. What is cold welding and how does it apply to asteroids?
Cold welding is a process where two pieces of metal can fuse together under certain conditions without the need for high temperatures. This process is relevant to asteroids because they are made up of various metal materials that can undergo cold welding in the vacuum and extreme temperatures of space.
2. Can asteroids really fuse together through cold welding?
Yes, it is possible for asteroids to fuse together through cold welding. Studies have shown that small particles of metal in space can bond together through this process, forming larger structures such as boulders or even entire asteroids.
3. What conditions are necessary for cold welding to occur on asteroids?
Cold welding on asteroids requires a vacuum environment, low temperatures, and a high amount of surface contact between the metals. These conditions are commonly found in space and on asteroids.
4. Is cold welding a common phenomenon in space?
Yes, cold welding is a common phenomenon in space. It has been observed in various experiments and has been theorized to occur naturally on small particles and debris in space. However, it is not as prevalent on Earth due to our atmosphere and higher temperatures.
5. How does cold welding affect the formation and composition of asteroids?
Cold welding can play a significant role in the formation and composition of asteroids. It can contribute to the growth of larger asteroids by fusing smaller particles together. It can also create unique structures and compositions within asteroids, as certain metals are more prone to cold welding than others.
  • Other Physics Topics
  • Quantum Interpretations and Foundations
  • Mechanical Engineering
