Undergrad Collapse of wavefunction into a forbidden eigenstate for a free particle
In quantum mechanics, free particles cannot possess definite energy or momentum due to the non-physical nature of their eigenstates, which are not square integrable. During measurement, a particle's wave function collapses to a state that is typically represented as a narrow Gaussian peak around the measured value, reflecting the uncertainty principle. Precise measurement of momentum leads to a wave function that is sharply peaked in momentum space, but this results in a flat position space representation, which is unphysical. The discussion highlights that while measurements yield values with uncertainty, achieving a precise measurement of position or momentum is fundamentally limited by both experimental and theoretical constraints. Ultimately, quantum mechanics describes particles as wave packets with inherent uncertainties, rather than as point particles with exact values.
Kashmir
For the free particle in QM, the energy and momentum eigenstates are not physically realizable since they are not square integrable. So in that sense a particle cannot have a definite energy or momentum.
What happens during measurement of say momentum or energy ?
So we measure some definite value of momentum or energy which is an eigenvalue of the momentum or Hamiltonian (since the operators commute for a free particle). Then we would in principle collapse the wave function to some eigenstate, but in this case we know that this is not possible (physically realizable).
So what happens during measurement and in what state is the particle after we've measured it's momentum?
Thank you
It's clear that for a free particle momentum or energy eigenstates cannot be prepared as the corresponding wave functions are not square integrable but belong to the dual of the domain, where position and momentum operators are defined, i.e., they are generalized functions or distributions.
One complete set are of course the momentum eigenstates, i.e., the plane waves,
$$u_{\vec{p}}(\vec{x})=\frac{1}{(2 \pi \hbar)^{3/2}} \exp(\mathrm{i} \vec{p} \cdot \vec{x}/\hbar),$$
and they are also the energy eigenstates with the corresponding eigenvalues ##E_{\vec{p}}=\vec{p}^2/(2m)##. They are of course not square-integrable but only normalizable to a ##\delta## distribution,
$$\langle \vec{p}|\vec{p}' \rangle=\int_{\mathbb{R}^3} \mathrm{d}^3 x u_{\vec{p}}^*(\vec{x}) u_{\vec{p}'}(\vec{x})=\delta^{(3)}(\vec{p}-\vec{p}).$$
Of course you can build all square-integrable wave functions in terms of these "eigenstates",
$$\psi(t,\vec{x}) = \int_{\mathbb{R}^3} \mathrm{d}^3 p u_{\vec{p}}(\vec{x}) \tilde{\psi}_0(\vec{p}) \exp(-\mathrm{i} E_{\vec{p}} t/\hbar).$$
Here ##\tilde{\psi}_0(\vec{p})## is the wave function in momentum representation at time ##t=0##, representing the state in which the particle is prepared at this "initial time", and it must be square integrable.
All these wave functions represent proper physical states and obey the Heisenberg uncertainty relations, ##\Delta x_j \Delta p_j \geq \hbar/2## for ##j \in \{1,2,3 \}##, i.e., if you prepare the particle with a pretty well determined momentum in ##j##-direction, it's localization in this direction is pretty uncertain and vice versa.
Likes Kashmir
We don’t know, because quantum mechanics is a theory about measurement results, not measurements.
It will be something like a very narrow Gaussian with a peak at the measured value; the more precise our measurement the narrower the Gaussian and the steeper the peak.
Likes Delta2, vanhees71 and Kashmir
Nugatory said:
We don’t know, because quantum mechanics is a theory about measurement results, not measurements.It will be something like a very narrow Gaussian with a peak at the measured value; the more precise our measurement the narrower the Gaussian and the steeper the peak.
And what if I measure a single value of momentum what will the wave function in momentum space look like? Or is it not possible to get a single value of momentum?
Yes, it's possible to get a single value. But, what your measurement equipment displays is not the issue. The issue is what your measurement equipment does, in terms of interacting with the particle. This was the basis of the so-called Einstein-Bohr debates, where they discussed how and why the HUP (Uncertainty Principle) was upheld in any experimental setup. This question, strictly speaking, is not the HUP, but is related.
In order to understand measurements of microscopic quantum systems, you must look closely at the precise details of how your apparatus interacts with the particle or system being measured. The question then becomes how you establish that, say, the particle had precisely zero momentum immediately after you measured it?
Likes hutchphd and Kashmir
if I'm getting just one precise value of momentum, what would be the wavefunction of the state in momentum space?
Until you say how you obtained that value of momentum, you can say nothing about the particle. At the very least, you must expect your apparatus to have an experimental error. That in itself (although technically unrelated to QM uncertainty) would undermine your claim to have measured the momentum precisely.
Moreover, from a mathematical point of view, a typical real number requires an infinite amount of information to describe it. A digital display can only display one of a finite number of values.
Before you even get to QM issue (that momentum eigenstates are unphysical), you already have two insurmountable technical problems: one experimental and one mathematical!
I didn't know those problems existed. Thanks for helping me realize them.
Can't we just for the arguments sake assume that we've somehow known the exact value of momentum and try to find the wavefunction. Or is your opinion that it's no use to think that way?
What QM is telling you is that a point particle is not part of the theory. And that particles are actually wave-packets: with a range of energy/momentum. That's what QM theoretically is telling you.
To imagine a pure point particle that has a definite, precise position in space is going against what QM is saying.
My point is that even before QM tells you this, the idea of experimentally establishing a precise set of real numbers ##(x, y, z)## that describe the position of a particle exactly at some precise time ##t## is not feasible. Even if the theory did not forbid point particles, it's not possible to measure them precisely.
The important thing is that particles are described by wave-packets, which have a range of energy/momentum, and an uncertainty in position that together obey the HUP. That's QM.
The momentum measurement works pretty much the same way: The wave function written in momentum space ends up a sharply peaked Gaussian. The position space reresentation and momentum space representations are Fourier transformations of one another, so the more peaked the wave function in one representation (that is, the greater the precision with which the observable has been measured) the flatter the other representation is.
Likes Kashmir
To say that we know the exact value of the momentum is equivalent to saying that the wave function in momentum space is a delta function. If it were, then the wave function in position space would be a flat line (equal probability of the particle being found anywhere in the universe), a state that is clearly unphysical and also not square-integral.
So no, we can't make that assumption. Neither the position nor the momentum eigenstates are physically realizable.
Likes vanhees71
Hold on there. No measurement will ever give you a definite value of position or momentum, there is always an spread of the value.
In principle, In non-relativistic QM, you can make the uncertainty of the position (or momentum, but not both at the same time) of an electron smaller than any given positive number, but that doesn't mean you can actually make it zero.
Likes vanhees71
apart from experimental limitations does the theory restrict a precise measurement?
You get a value with some uncertainty. To describe the particle, if you don't know any other details than that you have measured a momentum with some standard deviation the most objective state you can choose is a mixed state, described by a statistical operator
$$\hat{\rho}=\frac{1}{Z} \exp \left [-\frac{(\hat{\vec{p}}-\vec{p}_0)^2}{2 \Delta p^2} \right]$$
with
$$Z=\mathrm{Tr} \exp \left [-\frac{(\hat{\vec{p}}-\vec{p}_0)^2}{2 \Delta p^2} \right].$$
This association of a statistical description with the given information is following the rule of information theory, according to which one should choose the description of the minimal prejudice in the sense that one should maximize the "missing information measure", which is the von Neuman entropy,
$$S=-\mathrm{Tr} (\hat{\rho} \ln \hat{\rho})$$
under the given constraints, which are here the expectation value and standard deviation of the momentum.
Yes. As Nurgatory pointed out, a completely precise knowledge of the eigenvalue of the momentum requires the wavefunction to be non-square integrable, and QM says that you can't have that.
More physically, the more precise you want to measure the position of an electron the more energy you have to put into the measurement. In the limite of complete determination of the position you would require infinite energy. I saw an article here in the forums with the reasoning, but I don't remember the title of it.
No it doesn't. The uncertainty relation is no restriction in the ability to measure something precisely but to prepare the system in a state, where this observable takes a certain value. In other words, it is impossible to localize a particle precisely at one point. You can only restrict it to some finite, though in principle arbitrarily small, region in space. The same holds for momentum, but if you make one of these observables very determined the other necessarily becomes less determined.
Likes Lord Jestocost
The theory does not restrict the precision of any single measurement - we can have has many significant digits in our measurement result as our measuring device is good for. In mathematical terms, the Gaussian wave function after measurement can made arbitrarily narrow and steep. However it's still a Gaussian and not the physically unrealizable delta function so if we repeat the measurement there is some probability that we will get a different result.
Likes PeroK and vanhees71
vanhees71 said:
No it doesn't.
Yes, it does. It says that you cannot have a delta function as a result of a measurement; you can only have a Gaussian with some finite width. That is a restriction.
That's the usual misleading interpretation of the "collapse". A measurement does not necessarily imply the preparation of the measured system in the measured eigenstate. Indeed, you cannot prepare a particle in a state described by a plane wave, because this is not a proper state to begin with. However, this does not imply that you can't measure position or momentum with arbitrary precision.
vanhees71 said:
No it doesn't.
You are talking past one another, I think. Vanhees is saying that there is no theoretical limit to the precision of a measurement, which is to say the non-zero width of the Gaussian can be arbitrarily small - but still non-zero.
Likes vanhees71
And what I also want to say is that a measurement NOT necessarily leads to the preparation of a particle in an eigenstate of the measured observable.
The quantum state describes a preparation procedure. The fact that there are no proper eigenvectors of position and momentum thus implies that you cannot prepare a particle in a state with precise position or precise momentum. This is what's described by the position-momentum uncertainty relation ##\Delta x_j \Delta p_j \geq \hbar/2##.
It does not limit in any fundamental way, who precisely you can measure position or momentum of a particle.
vanhees71 said:
And what I also want to say is that a measurement NOT necessarily leads to the preparation of a particle in an eigenstate of the measured observable, but I think we drift apart into the realm of interpretation...
but my book did say that the collapse is into an eigenstate.
Likes gentzen and vanhees71
I know that many books include the collapse postulate, but it is at least very problematic, and the books do not discuss the problems in great detail.
Which textbook are you reading?
Likes Dr_Nate, gentzen and Kashmir
Mcintyre. Quantum mechanics.
He says "
After a measurement of ##A## that yields the result ##a_n##, the quantum system is in a new state that is the normalized projection of the original system ket onto the ket (or kets) corresponding to the result of the measurement:
##\left|\psi^\prime\right> = \frac{P_n\left|\psi\right>}{\sqrt{\left<\psi\right|P_n\left|\psi\right>}}##"
Likes PeroK
Does your book also say that eigenstates of position and momentum are not normalizable and hence not physically realizable?
If so, then taken literally, your book is saying two contradictory things. Do you think it actually means both of those things literally?
Likes Dr_Nate and Kashmir
This implies that a delta function wavefunction in momentum space would give only one value on measurement. So the probability of measuring that particular eigenvalue should be ##1##.
If ##P## is the probability density then ##P d p=|\varphi(p)|^{2} d p## will give me the probability of getting a momentum value in a range ##dp## around ##p##
If Dirac delta function represents a state that results in only one measured value ##p##, we should then have ##P d p=|\varphi(p)|^{2} d p =1 ## but ##\varphi(p)=\delta\left(p-p^{\prime}\right)## so ##\delta^{2}(p-p) d p \neq 1##
So how does a Dirac delta function correspond to a single measurement of ##p## ?
@Nugatory ,@vanhees71 ,@PeroK , can you help me here?
For me the only way out of the difficulty without violating both of the statements is if we can't know momentum exactly ,even in theory.
If that's true then the wavefunction cannot collapse into an eigenstate because we didn't find a single value of momentum, the collapse will be into a superposition state.
That’s a simplification used by many intro textbooks to avoid some unpleasant mathematical complications associated with continuous spectrum observables. Unfortunately it leads to the contraction that you’re seeing. More advanced texts will straighten out this out with a more mathematically rigorous treatment.
Edit: and I see that @PeroK has already mentioned Sakurai as one that does.
Likes Kashmir
He says "
From a mathematical point of view, that's explicitly for an operator/measurable with a countable spectrum and, therefore, excludes position and momentum, which have an uncountable spectrum. Sakurai, for example, definitely discusses the two cases separately.
I'd bet McIntyre does the same thing.
Likes Kashmir
In the sense that a Gaussian in momentum space is a "superposition" of different values of momentum, yes, this is true.
Likes Kashmir
