MHB College-_-'s question at Yahoo Answers regarding a volume by slicing
  • Thread starter Thread starter MarkFL
    Volume
The discussion centers on calculating the volume of a solid with a triangular base and equilateral triangle cross-sections perpendicular to the y-axis. The solid is defined by the triangular region with vertices at (0, 0), (4, 0), and (0, 4), and the relevant equations for the triangle's sides are provided. The volume is determined using the formula for the area of an equilateral triangle and integrating the volume elements from 0 to 4. The final volume is calculated to be 16/√3 cubic units. The conversation emphasizes the importance of correctly identifying the volume as cubic rather than square units.
MarkFL
MHB
Here is the question:
Volumes of solids of revolution?
I have a problem in calculus 2 the question is:
"Find the volume V of the described solid S.
The base of S is the triangular region with vertices (0, 0), (4, 0), and (0, 4). Cross-sections perpendicular to the y-axis are equilateral triangles."
I drew a picture of the triangle but don't know how to find the volume. I know that because the cross sections are perpendicular to the y-axis that means it is rotated about the y-axis to get the solid and that the equations of the three lines that make up this triangle are y=0, x=0, and y= -x+4. I read the explanation to a similar problem but it made no sense and didn't help me with figuring out the answer to my problem. What's the answer? How do I solve it?
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello College-_-,
First, I want to say the this is a volume by slicing, nor a solid of revolution. We will be slicing or decomposing this solid into volume elements which are slices in the shape of equilateral triangles.
Slicing perpendicular to the $y$-axis, we find the width of the base area $S$ is the $x$-coordinate of the line along with the hypotenuse lies. Knowing the two intercepts of this line are both $4$, we may use the two-intercept form of a line, and then solve for $x$:
$$\frac{x}{4}+\frac{y}{4}=1$$
$$x+y=4$$
$$x=4-y$$
Now, we wish to find the formula for the area of an equilateral triangle as a function of its side lengths $s$:
$$A=\frac{1}{2}s^2\sin\left(60^{\circ} \right)=\frac{\sqrt{3}}{4}s^2$$
Hence, we may state the volume of an arbitrary slice of the solid as:
$$dV=\frac{\sqrt{3}}{4}(4-y)^2\,dy$$
Summing all the volume elements, we find the volume of the solid is then given by:
$$V=\frac{\sqrt{3}}{4}\int_0^4 (4-y)^2\,dy$$
Let's use the substitution:
$$u=4-y\,\therefore\,du=-dy$$
and we have:
$$V=\frac{\sqrt{3}}{4}\int_0^4 u^2\,du$$
Applying the FTOC, we obtain the volume in units cubed:
$$V=\frac{\sqrt{3}}{4}\left[\frac{u^3}{3} \right]_0^4=\frac{\sqrt{3}}{4}\cdot\frac{4^3}{3}=\frac{16}{\sqrt{3}}$$
I'm sure you mean the volume is in CUBIC units, not square :P
Why yes...yes I did. Thanks for catching that! I have fixed my post above. :D
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
