B Colliding balls: Conservation of momentum and changes in kinetic energy?
The discussion explores the relationship between momentum and kinetic energy in the context of collisions, specifically using the example of cue balls. It highlights that while momentum can be conserved in a collision, kinetic energy may not be conserved due to energy being transformed into other forms, such as heat and sound. The initial confusion arises from the assumption that a lighter ball can have greater kinetic energy while maintaining the same momentum as a heavier ball. Clarification is provided that in a perfectly elastic collision, the final velocities of both balls differ, demonstrating that energy is not "created" but redistributed. Ultimately, the conversation emphasizes the importance of applying both conservation laws to understand the dynamics of collisions accurately.
cueballbullet
I got curious about firearm ballistics and googled something similar to "bullet momentum vs kinetic energy".
IIRC, momentum P = mv (checked); and kE = (mv^2)/2 (also checked).
So I essentially wondered if it's worse to get hit by a bullet with greater kE than by one with lesser kE, presuming that P remains the same (same momentum (also same shape and size); yet different masses and velocities).
Quickly I learned that the faster, lighter bullet causes more damage and has (/because it has) more kE, as the greater amount of kE gets transferred to the bodily tissues.
Cool. Yet this led me to wonder about something else:
Posit that a rolling cue ball, B, of mass M, moving at velocity V, hits another cue ball, b, of mass M/2. If momentum is conserved, then the latter, lighter cue ball, b, will start rolling at velocity 2V... So, same momentum, and different velocities. This means that b has greater kinetic energy than B.
Everything makes sense in my non-physicist mind up until that last sentence. For the life of me I can't guess at all where that extra energy comes from. Same momentum, but twice the speed, because of half the weight. Cool. But again, if the momentum is indeed the same, but the speeds are different, then the kE should also be different, right? How does this work? I may have misunderstood something along the way and perhaps the energy is not greater in b than in B, afterall.
You are assuming that the rolling ball transfers all its momentum to the second ball, then stops dead. That's not how it works. To figure out the speeds of both after the collision, one must apply both conservation of momentum (total momentum of both) and conservation of energy. (If anything, in a real collision, some of the energy will be "lost" to heat and sound.)
That's good instinct to sense something's not right. The answer: There is no extra energy!
Just for fun, here are the final speeds of each. (Assuming a perfectly elastic head-on collision, which is the simplest to analyze.)
Final speed of the first ball: V/3
Final speed of the second ball: 4V/3
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
