What Is the Minimum Energy for Neutron Production in a Lithium-Helium Collision?
In summary: For the second root to be positive, the value of the discriminant must be positive, and then ##E_0 > 4.4 ##QED
geoffrey159
535
72
A thin target of lithium is bombarded by helium nuclei of energy E0. The lithium nuclei are initially at rest in the target but are essentially unbound. When a Helium nucleus enters a lithium nucleus, a nuclear reaction can occur in which the compound nucleus splits apart into a boron nucleus and a neutron. The collision is inelastic, and the final kinetic energy is less than E0 by 2.8 MeV. The relative masses of the particles are: helium, mass 4; lithium, mass 7; boron, mass 10; neutron, mass1. The reaction can be symbolized [tex]^{7}Li+^{4}He \to ^{10}B+^{1}n-2.8MeV[/tex]
a. What is E0,threshold the minimum value of E0 for which neutrons can be produced? What is the energy of the neutrons at this threshold?
( Ans: neutron energy = 0.15MeV)
b. Show that if the incident energy falls in the range E0,threshold<E0<E0,threshold+0,27 MeV, the neutrons ejected in the forward direction do not all have the same energy, but must have either on or the other of two possible energies. (You can understand the origin of the two groups by looking at the reaction in the center of mass system.)
## Q = 2.8 Mev##
## \theta = (\vec v_B,\vec v_N) ##
Energy equation :
## E_0 = E_B + E_N + Q##
Momenta equation:
##\left\{
\begin{array}{}
\vec P_i = 4\ \vec v_{0} \\
\vec P_f = 10\ \vec v_B + \vec v_N
\end{array}
\right.
[/B]
Hello, I have reached a dead end with this problem and I'd greatly appreciate some help.
My idea for solving question (a) is to isolate ##E_0## and study the solutions of ##\frac{dE_0}{dE_n} = 0 ## that are positive ( a nul solution means that no neutron is produced, and a negative solution is non physical ) , and then study the sign of the second derivative.
The first steps are to write the conservation of momentum equation, and apply the right substitutions with the energy equation:By conservation of momentum, ## \frac{|\vec P_i|^2}{4} =\frac{|\vec P_f|^2}{4} ##, so
## 4 v_{0}^2 = 25v_B^2 + \frac{1}{4} v_N^2 + 5 v_bv_n\cos(\theta) ##
In terms of energy, that previous equation is equivalent to
## 2E_0 = 5 E_B + \frac{1}{2} E_N + \sqrt{10} \sqrt{E_BE_N} \cos(\theta) ##
Using ## E_B = E_0 - E_N - Q ##, I get :
## 3E_0 -\frac{9}{2}E_n - 5Q + \sqrt{10} \sqrt{(E_0 - E_N - Q)E_N} \cos(\theta) = 0 ##
And I am stuck because I don't see any easy way to isolate ##E_0## !
The hint is given in the problem statement. The threshold is 2.8 MeV in the centre of mass frame. But in the lab frame where the Lithium starts at rest the threshold is different. Transform the COM frame and do the problem there. Then transform back to the lab.
In the COM frame the two initial particles start with mirror momentums, one from the left, one from the right. They will be moving at different speeds but have equal magnitude momentums with opposite signs. After, by conservation of momentum, the resultant particles will fly away with again opposite sign momentums, but with less total energy.
Then as to the energy of forward-ejected neutrons, there is a trick. That seems to be the major point of this homework, so I'm not going to say any more.
Thanks ! Got it for part (a) !
The center of mass has constant velocity vector ##\vec V_c = \frac{4}{11} \vec v_0 ## due to momentum conservation during the collision.
In that coordinate system:
##\left\{\begin{array}{}
\vec v_{He,c} = \vec v_0 - \vec V_c = \frac{7}{11} \vec v_0 \\
\vec v_{Li,c} = \vec v_{Li} - \vec V_c = \frac{-4}{11} \vec v_0 \\
\vec v_{N,c} = \vec v_{N} - \vec V_c \\
\vec v_{B,c} = \vec v_{B} - \vec V_c
\end{array}\right.
Momentum in the COM system is ##\vec 0##, and the velocity vectors of particles are going in opposite directions. As a consequence,
## 10 v_{B,c} - v_{N,c} = 4 v_{He,c} - 7 v_{Li,c} = 0 ##
Now the expression of energy in the COM system is:
##\begin{array}{}
E_{0,c} := \frac{1}{2}( 4 v_{He,c}^2 + 7 v_{Li,c}^2 ) = \frac{7}{11}E_0 \\
E_{f,c} := \frac{1}{2}( 10 v_{B,c}^2 + v_{N,c}^2 ) = v_{N,c}^2
\end{array}
Initial energy is minimal when ##E_{f,c}=0##, so ##E_{0,c} =2.8MeV##
## \begin{align}
E_{f,c}=0 \Rightarrow& v_{N,c}^2 = 0 \\
\Rightarrow& \vec v_N = \vec V_c \\
\Rightarrow& E_N = \frac{1}{2}V_c^2 = \frac{4}{121}E_0 = \frac{4}{121}\times\frac{11}{7}E_{0,c} = \frac{4}{77}\times 2.8MeV \approx 0.15 MeV
\end{align}
geoffrey159 said:
##\begin{array}{}
\end{array}
There is a typo here, forgot a factor 11/20, but luckily it does not interfere with the rest.
Got (b) too thanks to you ;-)
By conservation of momentum in laboratory coordinates, if the neutron is ejected forward, then the helium nucleus and the neutron follow the same direction, which constrains the boron nucleus to follow the same direction.
Therefore, ## 4v_0 - v_N = 10 v_B##.
Squaring the left and right expression, and using conservation of total energy for substitutions, I get an expression of neutron energy depending on helium nucleus energy:
## 11 E_N - 4\sqrt{E_0E_N}+(28-6E_0) = 0 ##
Then, neutron energy is given by the positive, real solutions of a second degree equation. Its discriminant is ##\triangle = 4 (70E_0 - 308) ##.
The solutions are real when ##\triangle > 0 ## which means that E_0 must be greater than ## \frac{308}{70} = 4.4 = E_{0,threshold}##.
In that case,
## E_N = \frac{1}{11} (2\sqrt{E_0} \pm \sqrt{70E_0 - 308})##
One root is obviously positive, the other one must satisfy the following condition:
## 2\sqrt{E_0} > \sqrt{70E_0 - 308} \Rightarrow E_0 < \frac{308}{66} \approx E_{0,threshold} + 0.27 ##
Hello, thank you for your response. I would suggest approaching the problem by considering the conservation of energy and momentum in the center of mass frame. In this frame, the total initial momentum is zero, and the total energy is equal to the sum of the masses of the particles.
Using the energy equation, we can write:
##E_0 = E_B + E_N + Q##
In the center of mass frame, the initial momenta of the particles are equal and opposite, so we can write:
##\vec P_i = -\vec P_f##
Using the momenta equation, we can write:
##4\vec v_0 = -10\vec v_B - \vec v_N##
Squaring both sides and using the fact that ##\vec v_0## is equal to the initial velocity of the helium nucleus, we can write:
##16v_0^2 = 100v_B^2 + v_N^2 + 20v_Bv_N\cos(\theta)##
In terms of energy, this becomes:
##4E_0 = 10E_B + E_N + 2\sqrt{10}\sqrt{E_BE_N}\cos(\theta)##
Now, we can use the fact that the total energy in the center of mass frame is equal to the sum of the masses of the particles to write:
##E_0 = 4 + E_B + E_N##
Substituting this into the previous equation, we get:
##3E_B + 3E_N + 4 = 10E_B + E_N + 2\sqrt{10}\sqrt{E_BE_N}\cos(\theta)##
Rearranging and squaring both sides, we get:
##(9E_B - E_N - 4)^2 = 40E_BE_N\cos^2(\theta)##
Using the identity ##\cos^2(\theta) = 1 - \sin^2(\theta)##, we can write:
##(9E_B - E_N - 4)^2 = 40E_BE_N - 40E_BE_N\sin^2(\theta)##
Using the fact that ##E_B = E_0 - E_N - Q##, we can write:
##(9E_0 - 10E_N - 9Q - 4)^2 = 40E_0E_N -
Related to What Is the Minimum Energy for Neutron Production in a Lithium-Helium Collision?
1. What is a "collision" in terms of physics?
A collision in physics refers to the interaction between two or more objects that results in a change in their motion or energy. This can occur between particles, atoms, or larger objects such as planets.
2. What is the relationship between collision and energy threshold?
The energy threshold in a collision refers to the minimum amount of energy that is required for a collision to occur. It is directly related to the speed and mass of the objects involved in the collision. If the energy of the objects exceeds the energy threshold, a collision will occur.
3. How does the energy threshold affect the outcome of a collision?
The energy threshold is important in determining the outcome of a collision. If the energy of the objects involved is below the threshold, they will not collide and will simply pass by each other. However, if the energy exceeds the threshold, the objects will collide and the resulting outcome will depend on factors such as the masses and speeds of the objects.
4. Can the energy threshold be calculated?
Yes, the energy threshold can be calculated using the equation E = 1/2mv^2, where E is the energy threshold, m is the mass of the object, and v is its velocity. This equation can also be rearranged to solve for the mass or velocity of an object, given the energy threshold and one of the other variables.
5. How does the energy threshold relate to the concept of kinetic energy?
The energy threshold is directly related to the concept of kinetic energy, which is the energy an object possesses due to its motion. As the kinetic energy of an object increases, so does its speed and therefore its energy threshold. This means that as an object gains more kinetic energy, it becomes more likely to collide with other objects.
