Collision between two masses with spring
In summary, the problem involves two masses with different velocities colliding head-on in a perfectly elastic collision. One of the masses has a spring attached to it with a spring constant of 2000N/m. The question asks for the maximum compression of the spring and the velocities of the two masses after the collision. Conservation of momentum and energy can be used to solve for the maximum compression of the spring, but the final velocities of the masses will depend on the reference frame used.
colmes
Mass 1 weighs 10kg and has a velocity of 5m/s [E], Mass 2 weighs 5 kg and has a velocity of 8m/s[W]. Additionally, mass 2 has a spring attached to it with k = 2000N/m. The two masses collide head-on in a perfectly elastic collision. What is the compression of the spring and what is the velocity of the two masses after the collision?
m1v1 + m2v2 = (m1+m2)v'
Energy of Spring = 0.5k(dx)²
0.5mv'² + 0.5k(dx)² = 0.5m1(v1)² + 0.5m2(v2)²
I was able to calculate the compression of the spring by using conservation of momentum and energy but I am not sure how I should find the velocities of the two masses after the collision. Should I use these equations below?
It is an elastic collision at the end, is it not? Energy is conserved, but that of the spring is zero when the masses are separated. So you can use the equations for the velocities, valid for elastic collision. But the last sentence uses singular "what is the velocity of the two masses after the collision?", that might be the common velocity v' at the maximum compression of the spring.
ehild
Not sure I understand the set-up. Is the spring in between the masses? On the other side of mass 1, attached to something else?
What does this mean:
What is the compression of the spring ... after the collision?
If the spring is involved in the collision, when does the collision end?
The spring is attached to one of the masses, and to nothing else.
Yes, the word "collision" has been used in different senses here in PF already. Collision is assumed instantaneous, is it not? But sometimes the interaction between the "colliding" objects take some time, and the collision begins when the objects start to interact (one object touches the spring on the other object) and ends when they do not interact any more The first object detaches from the spring).
ehild
So its other end is free? And it is not in the line between the masses? No mass is given for it, so I fail to see how it comes into the calculation. We might as well be told one mass is red.
Well, the text is not accurate, but there are quite a few such problems ... The spring must be in the line between the masses, which collide head on, how would it be compressed otherwise?
ehild
That's reasonable, but that led to my other question in post #3: when is "after the collision"? Wouldn't that be when the spring is no longer compressed at all? Maybe it means at closest point of the two masses, i.e. maximum compression. But then, is it the velocity of the masses at that time which is also wanted?
I think, the last (rather sloppy) sentence of the problem was meant as "What is the maximum compression of the spring during the collision and what are the velocities after the collision". The velocities are not constant during the time the masses interact with the spring.
ehild
ehild
Yes, those would be the natural questions to ask.
Yes, but the last question of the original text is in singular :confused:.
ehild
Not liking the wording on this questions at all but here goes...
Going with conservation of energy, at the point where the two objects are just about to collide the KE there should equal the PE when the spring is fully compressed. (no non-conservative forces, so no loss of energy, and when the spring is fully compressed there would be no KE)
KEi = 1/2 m1v1,i2 + 1/2 m2v2,i2
KEi = 1/2 (10kg)(5m/s)2 + 1/2 (5kg)(8ms)2
KEi = 285 J
So if KE intial is 285 J, then PE when spring is fully compressed = 285 J.
No PE due to gravity or other sources. So all PE in spring.
PE = 1/2 k x2 = 285 J → x = √[(2 * PE)/k]
∴ x = 0.53 m
or so i think...
If you consider the energy in lab reference frame, not all the KE is converted into PE.
The center of mass of the system is moving even when the spring is at maximum compression.
The velocity of the CM (nonzero in this problem) is not changed by internal forces.
In a perfectly elastic collision as the problem seems to be referring to all KE would be transferred to PE. (There would also be no sound or friction, among several other conditions that I know not enough about to discuss)
But if this problem is for a intro level physics course I'm pretty sure it's safe to use the law of conservation of energy and use 'ideal' conditions.
So you think that the momentum is not conserved in this collision?
What is the total momentum before the collision? What will be if the two balls have zero velocity (their KE is zero)?
Your statement applies only if the total momentum is zero. Condition always true in the center of mass frame but not always in the lab frame.
You know it wrong. Conservation of momentum applies. The spring is compressed by the two objects approaching. When they move with the same velocity (the velocity of the CM) the spring is not compressed further.. The initial KE of the masses is converted to the KE of the whole system + PE of the spring.
ehild
Related to Collision between two masses with spring
1. What is a collision between two masses with spring?
A collision between two masses with spring is an event where two objects, each with their own mass, collide with each other while connected by a spring. The spring acts as a medium for the transfer of energy between the two masses during the collision.
2. How does the spring affect the collision between the two masses?
The spring affects the collision between the two masses by storing and releasing energy during the collision. When the masses collide, the spring compresses or stretches, absorbing some of the kinetic energy of the masses. This energy is then released, causing the masses to bounce back in the opposite direction.
3. What factors affect the outcome of a collision between two masses with spring?
The outcome of a collision between two masses with spring is affected by factors such as the masses of the objects, the stiffness of the spring, and the initial velocities of the masses. The angle at which the masses collide and the coefficient of restitution (a measure of how bouncy the objects are) also play a role in the outcome.
4. How is momentum conserved in a collision between two masses with spring?
Momentum is conserved in a collision between two masses with spring because the total momentum of the system (the two masses and the spring) remains constant before and after the collision. This means that the combined mass and velocity of the two masses and the spring do not change during the collision.
5. Can the spring be damaged during the collision between two masses?
It is possible for the spring to become damaged during a collision between two masses. If the collision is too forceful, the spring may exceed its elastic limit and permanently deform or even break. This can affect the outcome of future collisions between the two masses.
