Collision between two pucks, find the angle
In summary, when two hockey pucks collide, one with a mass of 0.050 kg and an initial velocity of 5 m/s in the x direction, and the other with a mass of 0.10 kg and at rest, the resulting velocities of the pucks can be found using the conservation of linear momentum equation. After the collision, the first puck flies off in a north-east direction with a velocity of 3 m/s at an angle of 73 degrees above the x-axis, and the second puck flies off in a southeast direction with a velocity of 2.5 m/s at an angle of 35 degrees below the x-axis.
jahrollins
25
Two hockey pucks collide with each other. Puck 1 has a mass of 0.050 kg and an initial velocity of 5 m/s in the x direction. It collides with puck 2 which is initially at rest and has a mass of 0.10 kg. The collision isn't head-on. After the collision, Puck 1 flies off in the north-east direction with a velocity of 3 m/s in an angle θA above the x-axis. Puck 2 flies off in the southeast direction with a velocity of 2.5 m/s in an angle θB below the x-axis. Find θA and θB.
Conservation of linear momentum
m1vf1 + m2vf2 = m1vo1 + m1vo2
So in the y:
m1vf1y + m2vf2y = m1vo1y + m1vo2y
0.05(3sinΘa) + 0.1(2.5sinΘb) = 0 + 0
0.15sinΘa + 0.25sinΘb = 0
In the x:
m1vf1x + m2vf2x = m1vo1x + m1vo2x
0.05(3cosΘa) + 0.1(2.5cosΘb) = 0.05(5) + 0
0.15cosΘa + 0.25cosΘb = 0.25
I'm lost as to where to go from here.
That should be m1vf1 - m2vf2, since the two pucks head off in opposite directions.
So in the y:
That should be 0.05(3sinΘa) - 0.1(2.5sinΘb), since the two pucks head off in opposite directions.
In the x:
Solve the two equations you got for theta-a and theta-b. (Hint: use some trig identities.)
Alright so since sin2Θ + cos2Θ = 1 then...
For y:
0.15sinΘa - 0.25sinΘb = 0
15sinΘa = 25sinΘb
225sin2Θa = 625sin2Θb
For x
15cosΘa = 25 - 25cosΘb
225cos2Θa = (25 - 25cosΘb)2
225cos2Θa = 625 - 1250cosΘb +625cos2Θb
Add together:
225 = 625 - 1250cosΘb + 625
-1025/-1250 = cosΘb
Θb = 34.915 = 35 degrees
Put into the other equation (15sinΘa = 25sinΘb)
15sinΘa = 25sin(34.915)
Θa = 72.541 = 73 degrees
Related to Collision between two pucks, find the angle
1. What is the collision angle between two pucks?
The collision angle between two pucks is the angle at which the two pucks come into contact with each other during the collision. It is typically measured in degrees or radians.
2. How is the collision angle calculated?
The collision angle can be calculated using the law of conservation of momentum and the law of conservation of energy. By analyzing the velocities and masses of the two pucks before and after the collision, the angle can be determined using trigonometric formulas.
3. Can the collision angle be negative?
Yes, the collision angle can be negative if the pucks collide in a clockwise direction. In this case, the angle is measured in the opposite direction, resulting in a negative value.
4. How does the collision angle affect the outcome of the collision?
The collision angle determines the direction in which the pucks will move after the collision. A larger angle will result in a greater change in direction and velocity for the pucks.
5. Are there any factors that can influence the collision angle?
Yes, there are several factors that can influence the collision angle, including the initial velocities and masses of the pucks, the coefficient of restitution (which determines how much energy is lost during the collision), and the surface on which the pucks are colliding.
