Collision of anti-hydrogen with matter
  • I
  • Thread starter Sasho Andonov
  • Tags
    Antimatter
In summary, the collision of anti-hydrogen with matter results in annihilation events where the anti-hydrogen particles interact with regular matter, producing high-energy photons, typically gamma rays. This process provides insights into fundamental symmetries in physics, such as charge-parity-time (CPT) symmetry, and helps researchers understand potential differences between matter and antimatter. Experiments involving anti-hydrogen collisions also aim to explore the characteristics of antimatter and its behavior under various conditions, contributing to the broader understanding of the universe's composition.
Sasho Andonov
TL;DR Summary
What will happen if anti-hydrogen colide with oxygen?
Fir the time being, the only anti-matter atom which was produced by humans is anti-hydrogen atom. I am wonbdering what will happen if this anti-hydrogen collide with normal atom of (for example) oxygen: What will be anihilated and what will survive?
One of protons in oxygen core will be lost by pair annihilation and the core will become nitrogen.
  • Skeptical
Likes mfb and Sasho Andonov
There's enough energy released from the annihilation to unbind the remaining nucleus many times over.
Likes Sasho Andonov, topsquark and Vanadium 50
And there is enough energy to produce pions. Many times over.
Likes mfb, Sasho Andonov and topsquark
I found a reference (three of them, actually) that anti-He was produced at Brookhaven National Lab (using the Relativistic Heavy Ion Collider) in 2011. Unfortunately, I do not have Journal access so I can't give a proper reference, but one report was from Phys.org, so it's probably legit.
But, obviously, take it with a grain of anti-NaCl! 🤓
-Dan
  • Haha
Likes pinball1970, Sasho Andonov and berkeman
But, anihilation of the positron with electron from oxygen will produce energy which cuold affect the process of panti-proton anihilation with proton fro oxygen core. Or maybe it will not... (????)
You certainly produce anti-tritons and anti-helium-3 in collisions. Don't know what the status of anti-alphas is. The rule of thumb is that each additional nucleon reduces the production by ~1000. So you have much more anti-He-3 than anti-He-4.
These are nuclei, not atoms.
Likes Nugatory, vanhees71, Sasho Andonov and 1 other person
Anti-He-4 nuclei have been detected by STAR and by ALICE. There is no stable nucleus with 5 nucleons so the next heavier nucleus would be lithium-6, which is suppressed by a factor ~106. We are still looking at individual events of anti-He-4, so we won't see lithium any time soon.
Antiprotons will readily react both with protons and neutrons, typically producing a couple of pions. Some of these can interact with the remaining nucleus, kicking out protons, neutrons, larger fragments, or even splitting the nucleus into multiple parts. Here are results for carbon, which isn't too different from oxygen. See page 28 for a distribution of products (neutrons are not measured in this case).
Likes Nugatory, Vanadium 50, vanhees71 and 1 other person
How are the antiatoms produced? At what speed do they arrive in matter?
The halflife of ground state orthopositronium against annihilation is 10-10 s. In multielectron atoms, molecules and solids, I suspect that the parapositronium nucleus has appreciable overlap with opposite spin electrons too, so its lifetime in ground state is in the same order of magnitude.
Lower excited states of hydrogen atom have halflife of 10-8 s unless forbidden. Positronium has lower reduced mass, but I suspect the halflives are still not longer than 10-7 s... but no shorter than 10-8 when having l, and 10-10 for s states.
What will a slow antiproton do inside matter? Eventually, it will be caught in a high l orbit of a specific nucleus, followed by a cascade of x-rays and auger electrons. But before it has picked the nucleus... when antiproton meets a film, what are its chances of annihilating with either hydrogen, carbon, nitrogen, oxygen, sulphur (of cysteine), silver or halogen (which one - chlorine, bromine, iodine?)?
Likes Sasho Andonov
Trap antiprotons, then trap positrons in the same spot (with a clever double-trap potential), some will react. Many of the produced atoms escape but some of them are trapped. There is no matter around so lifetimes of matter/antimatter systems are irrelevant for that process.
It will be captured by a nucleus and annihilate as discussed in the previous comments.
Likes Sasho Andonov and vanhees71
I found an article telling that antiproton in He is extraordinarily stable (microseconds), in contrast to other substances (picoseconds).
The reasoning seems to be as follows: an antiproton at high l orbit could deexcite by photon emission or Auger electron emission. In He, photon emission at high l is slow and Auger emission of the one electron somehow forbidden, so antiproton is long lived; in other atoms there are presumably more allowed Auger lines leading to rapid cascade. (And in protonium, there are no Auger lines, but protonium being neutral and having no electrons readily combines with other atoms).
If the cascade is allegedly in picoseconds, it is rather faster than the cascade of the positron? And therefore not affected by the annihilation of positron?
Likes Sasho Andonov
See page 3 of your link. For annihilation with proton, the average count of pions is 4,98 - I don´t understand how they get so big +-, the components do not add up! 5 is also the mode at 35%, the second is actually 6 at 23%. "Couple" is actually possible despite antiproton and proton having 6 quarks and antiquarks, at 0,38%. (One is impossible for momentum conservation. Rest mass allows a maximum of 13 regardless of charge).
See page 4 of same link. The graph is conspicuously absurd, and links to a source which is paywalled. But it suggests that even for heavy nuclei, most pions (and presumably their energy) fly away and only a small fraction is absorbed in the nuclei - and nuclei like C or O catch much less of the pions than even the small fraction heavy nuclei do.
If it is true, is absorption of pion energy stochastic or incremental process? That is, do the residual nuclei catch at least a few MeV of the annihilation energy, or are the averages averages of a small fraction of events where the nucleus is disrupted and substantial fraction where the pions just fly away leaving the residual nucleus in ground state?
Likes Sasho Andonov
The strong interaction can easily produce quark/antiquark pairs.
I said "a couple of pions", not "a pair". 3-7 pions are a couple of pions.
snorkack said:
But is suggests that even for heavy nuclei, most pions (and presumably their energy) fly away and only a small fraction is absorbed in the nuclei - and nuclei like C or O catch much less of the pions than even the small fraction heavy nuclei do.
Right.
Nucleons gaining a few MeV will typically fly away. That's possible, as discussed before. It's also possible that all the produced pions fly away and the nucleus stays as it is. It's random, unsurprisingly.
Likes Sasho Andonov
If neutral antihydrogen collides with matter, the positron from the antihydrogen will annihilate with an electron, most probably producing two 511 keV gamma rays. The antiproton will get captured into an atomic orbital and eventually lose energy and annihilate with a proton (or neutron). About half of the pions created in this reaction will probably escape the nucleus, the other half will be absorbed and most likely cause the nucleus to blow itself apart. With heavier nuclei, part of the nucleus may remain bound:
https://inis.iaea.org/search/search.aspx?orig_q=RN:14763524
Neutral pions usually decay to two gamma rays, charged pions decay (eventually) to electrons and neutrinos.
So the end result will be a few gammas, a few neutrinos, fast electrons, and some nuclear fragments. The gammas and charged particles will then lose energy by ionizing atoms in the surrounding matter, while the neutrinos will simply leave the scene without interacting further. The ionized atoms will eventually recombine and release the energy as heat and light.
After all the dust settles, you will have some slightly warmer matter with a few radioactive atoms left (and the escaped neutrinos, of course)...
FAQ: Collision of anti-hydrogen with matter
What happens when anti-hydrogen collides with matter?
When anti-hydrogen collides with matter, it annihilates with the corresponding matter particles. This process releases a significant amount of energy in the form of gamma rays and other particles, such as pions. The annihilation typically involves the anti-proton in anti-hydrogen interacting with a proton, and the positron interacting with an electron.
Why study collisions of anti-hydrogen with matter?
Studying collisions of anti-hydrogen with matter helps scientists understand fundamental symmetries in physics, particularly charge-parity-time (CPT) symmetry. It provides insights into the differences and similarities between matter and antimatter, which could help explain why the universe is predominantly made of matter.
How is anti-hydrogen produced for collision experiments?
Anti-hydrogen is produced by combining anti-protons with positrons. This is typically done in a controlled environment, such as a particle accelerator or a specialized facility like CERN's Antiproton Decelerator. The anti-protons are slowed down and trapped, then combined with positrons to form anti-hydrogen atoms.
What are the challenges in studying anti-hydrogen collisions?
One of the main challenges is creating and containing anti-hydrogen atoms, as they annihilate upon contact with matter. This requires sophisticated trapping and cooling techniques to keep the anti-hydrogen isolated from normal matter. Additionally, precise measurements are needed to study the properties and interactions of anti-hydrogen, which requires advanced detection and analysis technologies.
What are the potential applications of understanding anti-hydrogen collisions?
While the primary motivation is to advance fundamental physics, understanding anti-hydrogen collisions could have practical applications in fields such as medical imaging and cancer treatment through techniques like positron emission tomography (PET). In the long term, insights gained from antimatter research could contribute to the development of new technologies, including potential energy sources and propulsion systems for space travel.
