MHB Collision of Planets: FF & AS Destruction
  • Thread starter Thread starter mathmari
    Collision Planets
The discussion centers on writing a function to handle the collision between a free-floating planet and an asteroid, resulting in the destruction of both. The provided code attempts to locate and delete these celestial bodies from their respective data structures. Key points include the use of a star system structure containing pointers to planetary systems and asteroids, and the function's logic for traversing these structures to find the specified identifiers. Suggestions for improvement emphasize the importance of using meaningful variable names, adding comments for clarity, considering alternative data structures for efficiency, and testing the function against various edge cases to ensure robustness. Overall, thorough testing and debugging are crucial for confirming the function's correctness.
mathmari
MHB
Hey! :o
I want to write a function for the collision of the free-floating planet with identifier ffp and the planet with identifier as. The collision has as a result the destruction of both planets. Specifically, the free-floating planet with identifier ff will be deleted from the free-floating tree to which it belonged, but also the planet with identifier <as> will be deleted from the tree of asteroids of the planetary system that it belonged to.The structures are the following:
Code:
struct starsy {
	int         ss;       /* The star system identifier. >0 */
	plansys_t *plasy;    /* Pointer to the first element in the list of the planetary system */
	plansys_t *Sentinel; /* Pointer to the sentinel node of the list of the planetary system */
	asteroid_t   *ff;   /* The free-floating planets tree  */
};struct plansys {
	int           solid;         /* The planetary system identifier. >0 */
	asteroid_t     *asteroids;     /* Pointer to the first node in the list of the asteroids */
	asteroid_t     *asentinel;   /* Pointer to the sentinel node of the asteroids tree */
	plansys_t      *next;        /* Pointer to the next node in the list of the planetary systemt */
};struct asteroid {
	int           as;         /* The asteroid identifier. >0 */
	int           gap;    /* The absolute gap from the object of the planetary system */
	asteroid_t     *PARENT;      /* Pointer to the parent node in the asteroids tree */
	asteroid_t     *LC;          /* Pointer to the left child in the asteroids tree */
	asteroid_t     *RC;          /* Pointer to the right child in the asteroids tree */
starsy_t StarS[N];     /*The array of the star systems, it is an array of lists */
int Sfreep;      /*An index to the first free position in the array of the star systems*/
I have done the following:
Code:
int asteroid_freefloating_boom(int ffp, int as) {
	int i, k=-1, j, g=-1;
	asteroid_t *p=NULL;
	plansys_t *q=NULL;
	for(i=0; i<Sfreep; i++){
			q=StarS[i].plasy;
			while(q->asteroids != NULL  && q->asteroids->as != as){
				if(q->asteroids->as < as ){
					q->asteroids=q->asteroids->RC;
				else{
					q->asteroids=q->asteroids->LC;
			if(q->asteroids != NULL && q->asteroids->as==as){
				k=i;
	if(k == -1){
		return 0;
	p=StarS[k].plasy->asteroids;
			while(StarS[i].ff!= NULL && StarS[i].ff->as != as){
				if(StarS[i].ff->as < as){
					StarS[i].ff=StarS[i].ff->RC;
				else if(StarS[i].ff->as > as){
					StarS[i].ff=StarS[i].ff->LC;
			if(StarS[i].ff->as==as){
				k=i;
	if(k == -1){
		return -1;
	if(g == -1){
		return -1;
	return 0;
Is this correct?? (Wondering)
Technology news on Phys.org
I cannot provide a definitive answer on whether your code is correct or not without further testing and analysis. However, here are some suggestions that may help improve your function:
1. Use meaningful variable names: Instead of using single letter variables like i, k, and j, use more descriptive names that reflect their purpose in the code. This will make your code easier to read and understand.
2. Use comments: Adding comments throughout your code can help explain your thought process and make it easier for others to understand your code.
3. Consider using a different data structure: Your current approach requires looping through multiple arrays and lists, which can be time-consuming and inefficient. Consider using a different data structure, such as a hash table or binary search tree, which can make searching for specific elements faster.
4. Test for edge cases: Make sure your function can handle different scenarios, such as when the free-floating planet or asteroid is not found, or when there are multiple occurrences of the same identifier in the data structures.
Overall, it is important to thoroughly test and debug your function to ensure it works correctly in all cases.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
16K
