Collisions in the centre of mass frame
In summary, the angle of deflection in a collision is different in the centre of mass frame compared to the lab frame due to the horizontal movement of the particles appearing to decrease while the vertical movement stays constant. The process of finding angles of deflection in the centre of mass frame involves transforming between frames using a galilean transform and using the direction cosines of the velocity vectors. The velocity of the frame must also be taken into account.
Lucy Yeats
117
I've just found out that in the centre of mass frame, the angle of deflection in a collision is different from in the lab frame.
I vaguely understand why: if the frame you viewed the particles in was also moving but only horizontally it would make their horizontal movement appear to decrease while their vertical movement would stay constant, which would seem to decrease the angle.
I have no idea how you would go about finding angles of deflection in the centre of mass frame. Could someone help me derive/ tell me a formula for doing so?
The angle is a free parameter. The issue is transforming between the frames.
How would I go about transforming between frames?
Thanks for helping! :-)
Call one set of axes S. Let another set of axes, S', be co-incident with S. Let S' now move steadily in the +x direction, relative to S. Now suppose there's a particle moving with velocity components ux, uy, uz as described on the S axes. On the S' axes the components will be (ux-v), uy, uz. This is a galilean (non-relativistic) transform.
From the components you can find the direction cosines of the velocity vectors in the two frames. If the particle is moving in, say, just the x and y directions then it's even easier: in S, tanθ = uy/ux, whereas in S', tanθ' = uy/(ux-v)
Ah, I think I get it now- thanks.
Good! Despite my forgetting to say that v was the velocity of the S' frame relative to the S!
FAQ: Collisions in the centre of mass frame
1. What is the centre of mass frame?
The centre of mass frame is a reference frame in which the total momentum of a system is equal to zero. In other words, the centre of mass of the system is at rest in this frame.
2. Why is the centre of mass frame important in studying collisions?
The centre of mass frame is important because it allows us to simplify the analysis of collisions by reducing the problem from a three-dimensional system to a one-dimensional system. This makes it easier to calculate the velocities and energies of the particles involved in the collision.
3. How do you calculate the velocities of particles in the centre of mass frame?
To calculate the velocities of particles in the centre of mass frame, we use the conservation of momentum and energy laws. We set the initial momentum and energy of the system equal to zero and then solve for the velocities of the particles after the collision.
4. Can the centre of mass frame be used for all types of collisions?
Yes, the centre of mass frame can be used for all types of collisions, including elastic and inelastic collisions. It is a useful reference frame for simplifying the analysis of collisions and can be applied to any system of particles.
5. How does the centre of mass frame relate to the concept of momentum?
The centre of mass frame is directly related to the concept of momentum. In this frame, the total momentum of the system is equal to zero, which means that the momentum of each particle is equal and opposite to that of another particle in the system. This allows us to easily calculate the changes in momentum during a collision.
57K
