Color of Clouds: Dark Pink at Night, White in Morning?
  • Thread starter yash25
  • Tags
    Color
In summary, the clouds in the night are pink because of Rayleigh Scattering. The morning sky is blue because the scattering of shorter blue and red light cancels each other out.
yash25
Why is the color of the clouds dark pink in the night as compared to the black sky? Also..why is it white in the morning when the sky is blue..(is it because the cloud molecules scatter red wavelengths along with the blue ones? )
I've never seen pink clouds at night, unless you're talking about immediately after the sun sets. In that case, the sun is below your horizon, but the clouds are high enough up that their horizon is farther away. They just reflect what you previously saw as a red sunset.
Remember that clouds are merely water droplets along with some impurities such as dust and airborne pollutants.
Oh no..im not talking about the time when the sun sets.. Actually it's the monsoon season here..and the rain clouds appear pink in color against the black sky late in the night much after the sun has set. so ...i don't really know what must be happening in this case?
If it is long after sunset, the only things that could illuminate the clouds is light from the ground or the moon.
The color of the clouds comes from scattering, and there are many, many relevant scattering processes that can occur depending on the relative positions of the sources (sun, 'light pollution'), the observer (you) and clouds; the composition of the clouds, the polarization dependence, etc. etc.
Here's a great site to surf around:
http://www.atoptics.co.uk/
wow..maybe it is light pollution ! because i live in a metropolis...
I live in Toronto, and the clouds here are yellow/orange at night due to the city lights. But your clouds are pink?
I don't know why the colour is pink? Maybe it's because of some other reason.And the colour is a dirty pink.Im from Mumbai...
Maybe there's a large red light district hidden in the middle of your city? :biggrin:
If there's a lot of heavy manufacturing around, maybe iron dust is getting into the air?
No...that can't be...because I'm staying in a residential area. Ald my house faces the sea. The clouds on top of the sea also are pink in colour! They're slightly dirty pink(pink mixed in murky black?)
Speaking of sunset colours, can anyone tell me about the saying, "Red sky at night, shepherd's delight; red sky in the morning, shepherd's warning". I understand it is to do with predicting the weather. I do not know how accurate it is though.
I donlt know about accuracy, but http://en.wikipedia.org/wiki/Weather_lore#Red_sky_at_night" regarding the rationale of the saying:
"Weather systems typically move from west to east, and red clouds result when the sun shines on their undersides at either sunrise or sunset. At these two times of day, the sun's light is passing at a very low angle through a great thickness of atmosphere, the result of which is the scattering out of most of the shorter wavelengths — the greens, blues, and violets — of the visible spectrum, and so sunlight is heavy at the red end of the spectrum. If the morning skies are red, it is because clear skies to the east permit the sun to light the undersides of moisture-bearing clouds coming in from the west. Conversely, in order to see red clouds in the evening, sunlight must have a clear path from the west in order to illuminate moisture-bearing clouds moving off to the east."
In a nutshell:
A red sky at night means the sky is clear to the West, where the sun is setting. That clear weather will be arriving in the morning.
A red sky in the morning means that clear weather that has passed over is now in the East, and the sun's red rays are now lighting up the incoming, wet clouds.
Maybe it is dust or a sand storm if you are in the middle east.
If you're are saying that the clouds appear white during the day and the sky blue and that they clouds appear reddish and so does the sky at sunset then this is what everybody sees. Two words 'Rayleigh Scattering'.
http://en.wikipedia.org/wiki/Rayleigh_scattering
maverick_starstrider said:
If you're are saying that the clouds ... appear reddish and so does the sky at sunset
He's not saying that. He addressed this very question in https://www.physicsforums.com/showpost.php?p=2252108&postcount=3":
...the rain clouds appear pink in color against the black sky late in the night much after the sun has set.
yash25, Google nocto-luminescent clouds.
(Or variations such noctoluminescent, noctiluminescent, nocto-luminescent.)
Related to Color of Clouds: Dark Pink at Night, White in Morning?
1. What causes clouds to appear dark pink at night?
Clouds appear dark pink at night due to the scattering of sunlight by dust particles and pollutants in the atmosphere. This causes the shorter, blue wavelengths of light to be scattered, leaving behind the longer, red wavelengths that give clouds their pink hue.
2. Why do clouds appear white in the morning?
In the morning, the angle of the sun is lower in the sky, causing sunlight to pass through a thicker layer of atmosphere. This results in a greater amount of light being scattered, making clouds appear white.
3. Are dark pink clouds a sign of severe weather?
No, dark pink clouds do not necessarily indicate severe weather. While pink clouds can sometimes be associated with thunderstorms or strong winds, they can also simply be a result of atmospheric conditions and the angle of the sun.
4. Can the color of clouds change throughout the day?
Yes, the color of clouds can change throughout the day due to the changing position of the sun and the amount of atmospheric particles present. Clouds may appear pink, orange, or even red during sunrise and sunset, while they may appear white during the middle of the day.
5. Is there a scientific explanation for why some clouds have different colors?
Yes, the color of a cloud is determined by the size, shape, and composition of its water droplets or ice crystals, as well as the angle of the sun and the amount of atmospheric particles. Different combinations of these factors can result in clouds having different colors.
  • Other Physics Topics
  • Classical Physics
11K
