Column of water, vacuum pressure and a one-way valve problem
In summary, a conceptual problem related to a design I'm working on: If I use a pump to suck air out of the top of a vertical pipe, with the bottom of the pipe in water, I can only make the water rise around 10 metres inside the pipe, if I produce a perfect vacuum. However, if I place another one way valve at the bottom, then I don't need atmospheric pressure to support the column of water, since it can't escape from the column.
Anton Zhyzhyn
A conceptual problem related to a design I'm working on:
Now let's say the pipe was 100m long and around 90m was under water, such that my pump was just able to suck the water up to the top of the pipe (and thus remove all air from inside the pipe).
Now let's say the top of the pipe has a perfect one-way valve which prevents the water column from falling once I switch off the pump. Once the pipe is full of water, I turn off the pump and the column remains standing.
Now, say the surrounding water level outside the bottom of the pipe falls by around 1m, such that the top of the pipe is now 11m above the surrounding water level. The perfect one-way valve at the top remains closed.
What happens inside the pipe? Will my column of water still be standing, reaching to the top of the pipe? What governs this behavior and, if the water column can be more than 10m in this situation, what happens if the water level drops significantly further?
:welcome:
That is a very good question.
The low pressure will cause the water to boil even at room temperature, so steam instead of air will fill the top part of the pipe.
To prevent that from happening, you need a liquid other than water that won't boil or evaporate.
If we assume the water doesn't boil, the limiting factor is atmospheric pressure. You're making a really tall barometer. The height of the column of water above the surrounding water is fixed to atmospheric pressure and there is a vacuum above (all vacuums are the same, regardless of their volume).
You can watch an analogous experiment at 7:45 in this video:
I understand that your one way valve is at the top. If you place another one way valve at the bottom you will not have to support the column with atmospheric pressure, since it cannot escape from the column after atmospheric pressure has pushed it in.
I beg to differ.
If the vapour pressure of the liquid is significantly less than atmospheric pressure, which is normally the case, then the height of the supported column will have little to do with the vapour pressure above the liquid and much more to do with the density of the liquid.
In a barometer, atmospheric pressure is supporting the liquid column by pushing it up, while the vapour pressure above is pushing it down. The difference pressure is available to support the column. That column will have a height that is inversely proportional to the density of the liquid.
Crudely expressed, at sea level; Column height = 10.3 metre / density relative to water.
For water that works out at 10.3 metres, while for Hg with a density of 13.534 g/cm3 we get 760 mm.
Remember that both the density of a liquid and the vapour pressure are temperature dependent.
Related to Column of water, vacuum pressure and a one-way valve problem
1. What is a column of water?
A column of water is a vertical column or cylinder of water that is held in place by gravity. It is commonly used to measure the pressure and weight of water in a particular area.
2. How does vacuum pressure affect a column of water?
Vacuum pressure is the pressure exerted by a vacuum or empty space. When a column of water is placed in a vacuum, the pressure above and below the column becomes unbalanced, causing the water to rise or fall depending on the strength of the vacuum.
3. What is the purpose of a one-way valve in a column of water?
A one-way valve is used to control the flow of water in a column. It allows water to flow in one direction, preventing backflow and keeping the water in the column at a consistent pressure.
4. How does a one-way valve solve the problem of a column of water in a vacuum?
A one-way valve helps to maintain the pressure and stability of the column of water in a vacuum. Without it, the vacuum pressure could cause the water to rise or fall rapidly, potentially causing damage or instability.
5. What are some real-world applications of understanding column of water, vacuum pressure, and one-way valve problems?
Understanding how these factors interact can be useful in various industries, such as hydraulics, plumbing, and irrigation. It can also be crucial in designing and maintaining systems that involve water, such as aquariums and water treatment plants.
  • Classical Physics
  • General Engineering
  • Mechanical Engineering
