Combinations and Permutations Question
In summary, the conversation discussed finding the coefficients of certain terms in binomial expansions. The first question asked for the coefficient of x^43 in the expansion of [(2/x^2) - x^3]^16, while the second question asked for the coefficient of x^14y^12 in the expansion of (3x - 2y)^26. The equations used were the Binomial Expansion formula, and the solution involved finding the correct term in the expansion.
snaidu228
1) What is the coefficient of x^43 in the expansion of [(2/x^2) − x3)^16?
(2) What is the coefficient of x^14y^12 in the expansion of (3x − 2y)^26?
Binomial Expansion
For (1),
I started out like this:
(16 0) ( 2/x^2)^16 (-x^3)^0 + (16 1) (2/x^2)^15 (-x^3)^1 +...+ (16 16) (2/x^2)^0 (-x^3)^16.
Is that how we do it?
Do we do the same for (2)?
Hi snaidu228! :smile:
(try using the X2 tag just above the Reply box :wink:)
Yes, that's it (except, of course, you only need the one term that has x43). :wink:
(and similarly for (2))
Thank you very much!
FAQ: Combinations and Permutations Question
What is the difference between combinations and permutations?
Combinations refer to the different ways in which a selection of objects can be chosen without considering the order of the objects. Permutations, on the other hand, take into account the order in which the objects are arranged.
How do I calculate the number of combinations or permutations?
The formula for calculating the number of combinations is nCr = n! / (r! * (n-r)!), where n represents the total number of objects and r represents the number of objects in the selection. For permutations, the formula is nPr = n! / (n-r)!, where n and r have the same meanings as in combinations.
Can combinations and permutations be applied to real-life situations?
Yes, combinations and permutations are commonly used in various fields such as statistics, probability, and genetics to analyze and solve problems involving groups and arrangements.
How do I know when to use combinations or permutations?
If the problem involves selecting a group of objects without considering the order, then combination should be used. If the problem involves arranging or ordering objects in a specific sequence, then permutations should be used.
Are there any real-life examples of combinations and permutations?
Yes, some common examples include choosing a committee from a group of people, arranging a set of books on a shelf, and creating a password using a combination of letters and numbers.
