Combinations Formulae & Mapping to Index Values
  • Thread starter raminee
  • Tags
    Coding
In summary, the Combinations formulae will find the number of possible combinations that can be obtained by taking a sample of items from a larger set.
raminee
TL;DR Summary
How to come up with an indexing formulae for all set of combinations from a given set of numbers?
The Combinations formulae will find the number of possible combinations that can be obtained by taking a sample of items from a larger set.
C = n! / [r! * (n-r)! ]
Where n is the number of set samples and r is the number of desired selected samples.
So as an example say we have n=5 and r=2.
Here are all the possible 10 combinations for choosing 2 samples out of 5 samples as shown in attached picture.
Note a 1 is a selected sample.
My question is given a chosen sample combination can we come up with a formulae that can map it to its index value ??
So say we come up with combination samples 1 and 3 then how do we get to index 5 ??
Technology news on Phys.org
What do ,"chosen sample combination" and "index value" mean here?
In the example I have chosen we have 5 samples in our data set. So n =5.
I have selected r to be 2. So we are looking at 2 sample combinations out of 5.
As shown in the attached picture in my original post the 2 sample combinations are indicated as 1s.
So in the table first 2 samples combination is sample 0 and sample 1. Next combination is sample 0 and sample 2 and so on. There are a total of ten 2 samples combinations as shown in the table.
Now let's say we map each of the 10 combinations to an index value. This way rather than say what the 2 samples combinations are I like to give the index and use a formulae to calculate the 2 samples combinations.
So if I say index 5 then one should be able to calculate, through a known formulae, that the two chosen samples are samples 1 and sample 3 as shown in the table. And so on for each index value.
Hope this clarifies it a bit.
I think you should figure out first how to get the index from the two samples, ##s_1## and ##s_2##.
\mathrm{index} = \frac{1}{2} \left[ (2n-1) s_1 - s_1^2 \right] + (s_2 - s_1)
Thank you DrClaude for this formula.
Given the example I posted I assume n=5, S2 is S(i+1) and S1 is S(i) where (i) is the sample position from 0 to 4.
You formula works for the example that I have given and the index goes from 1 to 10 which is fine.
But I was looking for more of a generic way to code this regardless of the numbers in the data set or the number of samples chosen.
What happens when we choose 4 samples out of 10 data sets ? Here we get 210 possible combinations.
I know a long time ago I came across this problem and I believe there was a solution as how to decode a given index knowing (n) and (r). but I have lost the paper and I can not find it anywhere on line.
So if anyone knows how to do it in a more generic way pls do let me know.
I will play around with your idea to see if I can make it for other possibilities.
Thanks again
Let's see, sounds recursive to me.
With no attempts at optimization:
Code:
#include <iostream>
#include <algorithm>
#include <vector>
// Returns the index of a combination.
//  The combination is a sequence of "r" integers starting at s[i0].
//  Return value is the index of the combination "s" within a list of
//  "s.size()" combinations of "n" elements.
_int64 GetIndex(int n, std::vector<int>s)
   int i, v, r, rA, rB;
   _int64 nCount, nIndex;
   // Handle simple cases without recursion.
   r=(int)s.size();
   if((n<=0)||(r<=0)) return 0;
   v=s[0];
   if(r==1) return v;
   // Prepare for the recursive call.
   std::vector<int>::iterator it;
   std::vector<int> sR(s.begin()+1, s.end());
   for(it=sR.begin(); it!=sR.end(); it++) {
      *it = *it - v - 1;
   // Handle case where the first index is zero.
   if(v==0) return GetIndex(n-1, sR);
   //  Calculate the number of combinations when the first element is
   // zero: (n-1)!/[(r-1)!*(n-r)!] = (n-1)!/(rA!rB!)
   rA = std::max(r-1, n-r);
   rB = std::min(r-1, n-r);
   nCount = 1;
   for(i=rA+1;i<n;i++) nCount *= i;
   for(i=2;i<=rB;i++) nCount /= i;
   //  Count forward in the list of combinations until we get to the
   // first element.
   nIndex = nCount;
   for(i=1;i<v;i++) {
      // Increment by "n-i" elements taken "r-1" elements at a time.
      //  (n-i-1)!/[(r-1)!*(n-i-r)!]
      nCount *= n-r-i+1;
      nCount /= n-i;
      nIndex += nCount;
   return nIndex += GetIndex(n-v-1, sR);
int main()
   int v, minv;
   // From your example:
   int n = 5;   // The total number of possible values.
   std::vector<int>sRaw={1,3};  // The combination in question.
   // std::vector<int>sRaw={2,3,4};  // The combination in question.
   //   Our algorithm depends on values in range (0<=v<n) and in
   // ascending order.
   std::sort(sRaw.begin(), sRaw.end());  // Now an ordered list.
   std::vector<int>s;
   s.reserve(sRaw.capacity());
   for(minv=-1,it=sRaw.begin(); it!=sRaw.end(); it++) {
      v = *it;
      if((v>minv)&&(v<n)) {
         minv = v;
         s.push_back(v);
   _int64 index = GetIndex(n, s);
   std::cout << "Index is " << index << "\n";
Related to Combinations Formulae & Mapping to Index Values
What is the Combinations Formula?
The Combinations Formula is a mathematical equation used to calculate the number of possible combinations when selecting a specific number of items from a larger set without considering the order in which they are selected. It is given by nCr = n! / r!(n-r)!, where n is the total number of items and r is the number of items being selected.
How is the Combinations Formula used in real life?
The Combinations Formula is commonly used in probability and statistics to calculate the likelihood of certain outcomes in experiments and surveys. It is also used in fields such as genetics, where it can be used to calculate the number of possible gene combinations in a population.
What is Mapping to Index Values?
Mapping to Index Values is a process of assigning a numerical index to each element in a set or collection. This allows for a more efficient way of organizing and accessing data, as the index can be used to retrieve specific elements without the need for sequential searching.
What is the purpose of Mapping to Index Values?
The purpose of Mapping to Index Values is to improve the efficiency of data retrieval and organization. By assigning a unique index to each element, the data can be accessed quickly and efficiently without the need for lengthy searches. This is particularly useful in large datasets with a high volume of data.
How is Mapping to Index Values applied in computer science?
In computer science, Mapping to Index Values is commonly used in data structures such as arrays and hash tables. These data structures use indexing to organize and access data, making operations such as searching and sorting more efficient. It is also used in database management systems to improve data retrieval and query processing.
  • Set Theory, Logic, Probability, Statistics
  • Linear and Abstract Algebra
  • Electrical Engineering
