Combinatorics -- Counting Sets of Binary Strings
In summary: But yeah, that seems to work.In summary, the left side of the equation counts the number of elements in set S. The right side of the equation also counts the number of elements in set S. Therefore, the left side must be equal to the right side.
QuietMind
42
Give combinatorial proofs of the identities below. Use the following structure for each proof. First, define an appropriate set S. Next, show that the left side of the equation counts the number of elements in S. Then show that, from another perspective, the right side of the equation also counts the number of elements in set S. Conclude that the left side must be equal to the right, since both are equal to |S|.
a)
##\binom{2n}{n} \sum_{k=0}^n \binom{n}{k} * \binom{n}{n-k}##
b)
##\sum_{i=0}^r \binom{n+i}{i} = \binom{n+r+1}{r}##
Hint: consider a set of binary strings that could be counted using the right side of the equation, then try partitioning them into subsets countable by the elements of the sum on the left.
a)The left hand side is just choosing n out of 2n.
The right hand side is choosing a total of n out of 2n as well, but with the constraint that some k must be from one half, some n-k must be from the other. Thus you would need to sum across all of k up to n in order to all possible selections.
b) I'm having trouble understanding their hint. I've never seen counting attempted on a set of binary strings before, only on a singular binary string. I don't know what to do with the right hand side.
The left hand side I think I understand a little more: Each individual term ##\binom{n+i}{i}## is the way I've seen used to express the number of possibilities if you have an n+i binary string, choosing i of the bits to be 1's. If there's a summation from i=0 to r, then it seems to me that might be a set of binary strings from length n to n+r, and the number of possible combinations for each string is added up. However, I don't see how the right hand side relates to this. Am I on the right track?
a)
b)
For b)
RHS: the number of ways of building a binary string consisting of n+1 0's and r 1's.
Now, the first 0 can be at position 1, position 2, ..., position r, position r+1. That gives an interesting partitioning.
Likes QuietMind
Ok I think I have it:
Based on your partitioning, if the first 0 is at position 1, of the remaining n+r bits, there are n zeroes and r ones. Thus
##\binom{n+r}{r}##
If the first 0 is at position 2, of remaining n+r-1 bits, there are n zeroes, r-1 ones. Thus
##\binom{n+r-1}{r-1}##
Continuing, for first 0 at i+1 spot, of remaining n+r-i bits, there are n zeroes, r-i bits. Thus
##\binom{n+r-i}{r-i}##
and i can vary from 0 to r. This is essentially the summation on the LHS but with i counting backwards. It describes every possible appearance of the bit string, just like the RHS.
Does that seem right?
It didn't seem like anything in this problem was really a "set"... I guess maybe the set of all partitions.
##\binom{n+r}{r}##
Yes, that's exactly what I had in mind.
With "set", they probably meant the set of all binary strings consisting of n+1 0's and r 1's.
Or maybe there is a totally different solution: that can happen in these combinatorial exercises.
Likes QuietMind
FAQ: Combinatorics -- Counting Sets of Binary Strings
1. What is combinatorics?
Combinatorics is a branch of mathematics that studies the ways in which objects can be combined, arranged, or selected, often with the goal of counting the number of possible outcomes.
2. What are binary strings?
A binary string is a sequence of 0s and 1s, often used in computer science to represent data.
3. How do you count the number of sets of binary strings?
To count the number of sets of binary strings, you can use the formula 2^n, where n represents the number of digits in the binary string. This is because for each digit, you have 2 options (0 or 1), and the total number of sets is the product of these options for each digit.
4. What is the difference between a combination and a permutation in combinatorics?
In combinatorics, a combination is a way to select a subset of objects from a larger set, where the order of the objects does not matter. A permutation, on the other hand, is a way to arrange all the objects in a set in a specific order. In other words, combinations are about selecting, while permutations are about arranging.
5. How can combinatorics be applied in real life?
Combinatorics has many practical applications, including in computer science, statistics, and economics. It can be used to analyze and optimize algorithms, make predictions in probability and statistics, and solve problems in game theory and decision-making.
