MHB Combinatorics: Order in a line by 2 conditions
The discussion focuses on a combinatorial probability problem involving three shapes of pasta with varying weights. The main question is about the probability of arranging the packages so that either packages of the same weight are adjacent or each shape is separated. The user interprets the "and/or" phrasing as potentially indicating a union of two distinct situations, leading to confusion in calculating the probabilities. The calculations presented include total arrangements and arrangements for separate shapes, but the user struggles with integrating the conditions related to weights. Clarification on how to approach the "and/or" aspect and the grouping of weights is sought for a comprehensive solution.
Lancelot1
Hi all,
I need some help with this one:There are 3 shapes of pasta: 1,2,3.
In a box there are 3 packages of pasta of shape 1, with different weights: 300 gr, 400 gr, 500gr.
In addition, there are 5 packages of paste of shape 2, with weights: 300gr, 350gr, 400gr, 500gr, 600gr,
and 4 packages of pasta of shape 3, with weights 300gr, 350gr, 400gr, 500gr.
What is the probability that a random ordering of the packages on a shelf will be such that pasta packages of the same weight will be one next to another, and/or each shape of pasta will be separate ?
The and/or part of the question is unclear to me. My interpretation is to count all the possibilities in which the same weight is one next to another, or the shape is separate or both. Does it makes sense ?
This is a probability question, but the main problem is combinatorical.
The number of possibilities is clearly :
$(3+5+4)! = 12!$
The number of possibilities for separate shapes is:
$3!\cdot 3!\cdot 4!\cdot5!$
i.e, 6 possibilities to order the shapes, with all the inner possibilities within each shape, right ?
My problem is with the weights...
Mathematics news on Phys.org
The separate shape rationale looks good to me. I find the and/or language confusing, as these are usually distinct calculations. My instinct is to treat these as two problems since I can't think of a way to combine these logically and I've never seen a situation where this happens. Maybe it means this.
Situation 1: Random ordering of the packages on a shelf will be such that pasta packages of the same weight will be one next to another
Situation 2: Each shape of pasta will be separate
"and/or" could mean either Situation 1, Situation 2, or both Situation 1 and Situation 2 together. This is treating it as a union.
As for the weights, if we think of each weight as a group then there are 3 300gr packages, 2 350gr, etc. I think you can apply the same approach to this kind of grouping as you did to the package groupings.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
