Combustion/explosion reactions
  • Thread starter Infrasound
  • Tags
    Reactions
In summary: Energy is transferred between the particles by a phenomenon called "radiation". The radiation is a form of energy that travels as a wave. When two atoms collide, they emit radiation in all directions. This radiation is what causes the heat.Now, you might be thinking, "well, duh, that's why you have fire". But radiation isn't the only thing that causes heat. The heat actually comes from the motion of the particles. When the particles are vibrating, they are also moving the air around them. And since air is a gas, it takes in and releases heat.
Infrasound
70
combustion/explosion reactions - anyone have an explanation?
I am a layperson, desperately seeking enlightenment!
I have been thinking about combustion/explosion reactions and have been trying to build a mental model of the physical processes involved.
I can imagine two atoms, let's say carbon and oxygen snapping together. Where does the increase in temperature come from?
The only thing I have come up with is, maybe "other" atoms are attached to the carbon and/or oxygen before the reaction occurs. They get pulled along until the C and O snap hard together, and break loose from the collision.
Like people getting thrown from crashing cars.
So these "thrown" atoms contain all of the new released energy.
Thanks in advance anybody who can help!
All chemical bonds have a property called "enthalpy", which can be thought of as how badly two atoms "want" to be together. Carbon and oxygen really want to be together, so it takes energy to separate them. Energy must be conserved, so the energy that it would take to separate them is equal to the potential energy they have when they're apart, which is also equal to the energy they release when they come together. The released energy is in the form of heat.
Now, I have to admit, I haven't thought a lot about this on a molecular level. The thought of two atoms coming together and forming a molecule of higher kinetic energy is spooky to me. Maybe I can pass the torch off to someone at this point...
Ok, I already know about that principle. I have considered it, and I know it will be important to our problem, but we have still not answered the question. What actually happens to transfer this energy that will be released to other atoms nearby.
Another idea I have thought of is, maybe the collision/snapping together of the C and O alone causes their electrons to vibrate in their "orbits". Would that emit enough EM radiation to shake the nearby atoms sufficiently to explain a fire.
For some reason i doubt it.
Interestingly, this is one of the most common phenomena we experience in life (fire), yet I have never heard a complete physical explanation.
Is it possible that virtually no one really knows?
Thanks Archosaur, I appreciate your input. I just don't think we are there yet.
For a mental picture, think of bonds as little springs between magnets. When you bring two magnets close to each other, attraction snaps them together. The spring in between would prevent them coming completely together, but all that energy is still there, and it will make the two magnets bounce around quite a bit on that spring.
Same thing happens in a chemical reaction. After the two particles came together, they don't just stop, they keep vibrating on that "spring" of the bond between them. And since there is no friction, they keep vibrating until something mechanically hits them.
Now imagine a CO2 molecule, vibrating like crazy after being formed, encountering another CO2 molecule, equally vibrating. When they hit each other, odds are, all that vibration will result in the two parting much faster than they came together.
As a physics note, there is actually a theorem, called Equipartition Theorem, which states, in simple term, that left to their own devices, energy will distribute itself between particle motion, vibration, and rotation in a specific proportion. And motion of particles, of course, is related to temperature.
So basically, all that vibrational energy gets shared with mechanical energy. It works backwards too, if you heat a gas, part of the energy goes into vibration of the molecules.
Net result, of course, is the increase in gas temperature after combustion took place.
K2 - I have actually pictured that as a possible theory. It seems to make some sense without running the math.
The problem I had with that explanation was:
-The fact that on the original bonded pair (C-O), the oscillation from the bond would be in and out -giving a 50% chance of making contact with another atom while moving outward, and also a 50% chance of making contact with another atom while moving inward.
Wouldn't that result in zero net increase in energy for the environment?
Is this idea verified anywhere?
How do you picture collision when it's moving inward? Unless the other particle is moving at speed higher than that of vibration, in which case, that particle is already "hotter" than the one you're talking about.
And yes. You can look up Equipartition Theorem and see where it comes from with all related notes.
Related to Combustion/explosion reactions
1. What is combustion?
Combustion is a chemical reaction in which a fuel (such as a hydrocarbon) combines with oxygen to produce heat, light, and new chemical compounds, usually in the form of smoke or gas. This reaction is also commonly referred to as burning.
2. How does combustion produce energy?
During a combustion reaction, the chemical bonds of the fuel are broken and reformed with oxygen to create new, more stable molecules. The energy released from these bond formations is what produces heat and light. This energy can be harnessed and used for various purposes, such as powering engines or heating homes.
3. What conditions are necessary for a combustion reaction to occur?
For a combustion reaction to occur, three things are needed: fuel, oxygen, and heat. These three components make up the fire triangle. Without one of these elements, combustion cannot occur. This is why fires can be extinguished by removing one of these elements, such as smothering a fire with a fire blanket.
4. What is the difference between combustion and explosion reactions?
The main difference between combustion and explosion reactions is the speed at which they occur. Combustion reactions involve a slow and controlled burning process, while explosion reactions involve a rapid and uncontrolled release of energy. Additionally, explosion reactions often involve a much larger amount of fuel and oxygen, resulting in a more intense release of energy.
5. Are all combustion reactions dangerous?
No, not all combustion reactions are dangerous. Combustion reactions can be harmful, but they are also essential for many everyday processes, such as cooking and transportation. However, when not properly controlled, combustion reactions can lead to explosions, which can be dangerous and destructive.
  • Science Fiction and Fantasy Media
  • Mechanical Engineering
  • Chemistry
  • Biology and Medical
  • Other Physics Topics
