What is the Oxygen Content of Dry Flue Gas from Coal Combustion?
In summary, there are a few possible explanations for the differences in the oxygen balancing equation provided by the book. These could include accounting for moles instead of mass, and dividing the 'b' term by 2 to account for the number of oxygen atoms in each water molecule. It is important to carefully consider the units and variables used in the equations, as well as seek clarification from a colleague or professor if needed.
raniero
42
A quantity of coal used in a boiler had the following analysis: 82% C; 5% H; 6% O; 2% N; 5% ash. The dry flue gas analysis showed 14% CO2 and some oxygen. Calculate the oxygen content of the dry flue gas.
I have first written the formula for combustion including the variables for balancing the equation:
Considering 1kg of coal:
0.82/12 C + 0.05 H + 0.06/1 O + 0.02/14 N + x(0.233/32 O2 + 0.767/28N2) → B(0.14 CO2 + a O2 + (0.86-a) N2)+ b H2O
When balancing the equation this yields:
Carbon Balance: B = 0.4881
Hydrogen Balance: 0.05 = 2b → b =0.025
The problem I am encountering arises in the oxygen balancing:
Oxygen balance: 0.06/16 + x(0.233/32)2 = (0.14)2B + 2aB + b
The book's answer states: 0.06/16 + x(0.233/32) = (0.14)B + aB + b/2
How come the book's answer doesn't add double the amount of substance (kmol) as I did for Oxygen molecules?
Other answers from the book compensate by multiplying by two when molecules such as O2 are present. Another disagreement I have with the solution is the 'b' divided by 2.
Thanks in advance
for any help.
I am unable to comment on the specific answer provided by the book without further context or information. However, I can offer some general explanations for the differences in the answer.
Firstly, it is important to note that balancing chemical equations involves both mass and moles. In your calculation, you have correctly accounted for the mass of oxygen in the dry flue gas, but it is possible that the book's answer accounts for the moles of oxygen instead. This could explain the difference in the oxygen balancing equation.
Additionally, the book's answer may have divided the 'b' term by 2 in order to account for the fact that there are two oxygen atoms in each water molecule. This is a common practice in balancing equations, as it ensures that the number of atoms on each side of the equation is equal.
Overall, it is important to carefully consider the units and variables used in the equations, as well as the context of the problem, in order to arrive at the correct answer. If you are still unsure, it may be helpful to consult with a colleague or professor for further clarification.
Related to What is the Oxygen Content of Dry Flue Gas from Coal Combustion?
1. What is the process of combustion of coal in a boiler?
The process of combustion of coal in a boiler involves the burning of coal in the presence of oxygen to produce heat. This heat is then used to convert water into steam, which is then used to power turbines and generate electricity.
2. What are the benefits of using coal as a fuel in a boiler?
Coal is a relatively cheap and abundant source of energy, making it a cost-effective option for powering boilers. It also has a high energy density, meaning that a small amount of coal can produce a large amount of heat. Additionally, coal-fired boilers have a long lifespan and can be easily integrated into existing infrastructure.
3. How is air supplied to the boiler for combustion?
Air is typically supplied to the boiler through a forced draft fan, which blows air into the boiler and helps to maintain proper combustion conditions. The air is then mixed with the coal in the combustion chamber, allowing for efficient burning.
4. What is the role of ash in the combustion of coal in a boiler?
Ash is produced as a byproduct of the combustion process and is collected in the boiler's ash hopper. It serves several important functions, including providing insulation for the boiler and reducing the amount of heat that is lost. Ash also contains valuable minerals that can be used in other industries.
5. How can the efficiency of coal combustion in a boiler be improved?
The efficiency of coal combustion in a boiler can be improved through various methods, including using advanced combustion technologies, optimizing the air-to-fuel ratio, and regularly maintaining and cleaning the boiler. These measures can help to reduce emissions and increase the overall efficiency of the boiler.
27K
