Common Core Math in Elementary School
In summary: I'm not 100% sure if the old way is still taught.In summary, there is still a way to do arithmetic the old way, but the newer, more intuitive way is more common.
GladScientist
44
Hi everyone. I've been seeing certain posts circulate around social media, claiming that math is now taught differently in school than it was before. Here is one such image:
I'm not sure if this is true, or if it's just one of those "back in MY day" rants.
Anyways, I'd like to see discussion on whether or not this is true, and if it is, what are the reason(s) for this change?
Science news on Phys.org
First of all, let me point out that yes, the old way is still taught. Sometimes, you just need mindless, algorithmic processes to get a job done.
That said, the second method is more intuitive, and when I (and many other people who study in STEM fields) do mental arithmetic, this method is the method I use. It's highly unfeasible to imagine doing it the "old way" in your head--it's too easy to lose your place!
But it's much easier to take it one step at a time to simplify things. And this is exactly what I do: I subtract using a bunch of easy steps, and then take the total amount I subtracted. I don't pull out a sheet of paper and say "okay, now carry the one..."
Now, the old way is great. It works, but at the same time, it really isn't that necessary. Any sufficiently complicated problem can be solved with a calculator or computer. There's never any need to subtract a 13-digit number from a 14-digit number unless you just want to practice. What's more important when applying math is to understand intuitively what you're doing, and getting an intuitive feel for numbers is how you come up with those little tricks to make mental arithmetic easier.
For instance, what's [itex]15 \times 17[/itex]? I could pull out a sheet of paper and calculate it. I could also line the two up in my head and try to remember what the individual products are and then add them together, but that's the same as doing the following!
Notice that [itex]17 = 10 + 7[/itex], then [itex]15 \times 17 = 15 \times (10 + 7)[/itex]. That's much more manageable. Right away I know [itex]15 \times 10 = 150[/itex], and I can further divide [itex]7[/itex] into [itex]7 = 5 + 2[/itex]. Then I multiply 15 by each of those. That's fairly easy: [itex]15 \times 5 = 75[/itex] and [itex]15 \times 2 = 30[/itex], and in my head, I can add [itex]150 + 75 + 30 = 225 + 30 = 255[/itex]. I can do that in my head in about 5 seconds (or faster, if I'm in the zone!), because I know intuitively what it means to perform those operations. I don't need to rely on some algorithm without understanding what I'm doing.
Another example of a similar thought process. You're at the store, and you buy something that costs $3.72. You pay with a 20$ bill. How much change do you get? I'm not going to pull out a sheet of paper and calculate 20.00 - 3.72. I'm going to note that 3.72 + .28 = 4. Then note that 4 + 16 = 20. So my change is 16.28$. Again, it's hard to get that insight by just following a set of rules called subtraction. It requires understanding the meaning of subtraction.
And the beauty is that (I feel) those skills extend to higher level mathematics when you're no longer dealing with constants. That's where you're at an advantage when you understand what things mean as opposed to just how to do things. Understanding how to take a derivative is nearly useless unless your job requires you to analytically find derivatives. Understanding what a derivative is and how rates of change are all around us is the important skill.
Likes ELB27, epenguin, brainpushups and 3 others
That image has been spreading around social media. My wife teaches common core to 1st and 2nd grade. It took me several minutes to figure out the different approach, but I learned it's much closer to the method you likely use in your head as an adult. Breaking up the problem into easier units is much easier in your head than using remainders and carrying over tens. I'm a big fan of common core and the kids seems to pick it up just fine. It's the adults who are stuck in their ways who have a problem with it.
Likes BobG
I'm so impressed by the fact that the example you posted is actually correct. The worst are the posts where they don't do the steps correctly because they don't understand the concept they're criticizing.
Actually, in the example you posted, I'd go 568-300+7. If you're doing arithmetic in your head, at least make sure you get close to the right answer (-300). Then refine your answer to make it more exact (+7). But I was taught by my dad, not by a school system using common core. At the time, I thought that incredibly edgy that my dad, who always stressed playing by the rules, suddenly broke the rules (at least the rules I learned in school) when it came to doing quick calculations in your head.
Slightly off-point, but one can take the trouble to draw a picture, label the parts, and see immediately that the simple subtraction is what is really wanted:
568-293=275
and the units can be included if one wants to show them.
Related to Common Core Math in Elementary School
What is Common Core Math?
Common Core Math is a set of educational standards that outline what students in elementary and secondary schools should know and be able to do in mathematics at the end of each grade level. These standards were developed by a group of educators and experts to ensure that students are prepared for college and career success.
What is the purpose of Common Core Math?
The purpose of Common Core Math is to provide a consistent and clear understanding of what students are expected to learn in math, regardless of where they live. It also aims to prepare students to think critically, problem-solve, and apply mathematical concepts in real-world situations.
What are the main differences between Common Core Math and traditional math instruction?
Common Core Math focuses on developing a deep understanding of mathematical concepts, rather than just memorizing procedures. It also encourages students to think critically, communicate their reasoning, and use multiple strategies to solve problems. Traditional math instruction often focuses on rote memorization and following a set of steps to solve problems.
Why do some people have concerns about Common Core Math?
Some people have concerns about Common Core Math because they feel that it is too challenging or confusing for students, or that it is a departure from traditional math instruction. There have also been concerns about the implementation of the standards and the amount of standardized testing associated with them.
How can parents support their child's learning in Common Core Math?
Parents can support their child's learning in Common Core Math by familiarizing themselves with the standards and expectations for their child's grade level. They can also ask their child's teacher for resources and strategies to help their child at home. It is also important for parents to encourage their child to think critically, explain their reasoning, and persevere through challenging problems.
13K
  • STEM Educators and Teaching
  • STEM Academic Advising
10K
  • STEM Career Guidance
