Communication between Arduino and Matlab Help
In summary, the conversation was about trying to achieve real time plotting of accelerometer data using an Arduino, an Xbee, and Matlab. The Matlab program receives data in the format of X, Y, Z, and t. There were concerns about incomplete lines of code being mashed together with complete lines of code. The code for both the Arduino and Matlab were shared, with the suggestion to remove unnecessary elements and combine multiple print lines into one.
Jonathan_36
I am trying to achieve real time plotting of accelerometer data using an arduino, an Xbee, and Matlab. Usually when the Matlab program gets data, it gets something like this:
~ #� ' X: -2 Y: 20 Z: 4080 t: 33232
~ !� ' X: 4 Y: 2 Z: 4066 t: 33255
b~ &� ' X: 1090 Y: 218 Z: 4086 t: 33277
]~ %� ' X: -204 Y: 48 Z: 4084 t: 33300
¢~ $� ' X: 86 Y: 104 Z: 4060 t: 33323
which is fine, and is what I want but there are also times in which I will get data like this:Ï~ %� $ X: 210 Y: 116 Z: 4074 t~ #� $ X: -2 Y: -2 Z: 4074 t: 33684
~ #� $ X: 16 Y: -4 Z: 4084 t: 33707
~ "� $ X: -2 Y: 4 Z: 4064 t: 33729
where I will get an incomplete line of code mashed together with a complete line of code and I am stuck on how to fix this. Is there anything in my code I overlooked or is there something else I should try?
On the arduino side, the code is below:
Code:
#include <Wire.h>
#include "RTClib.h"
#include <Adafruit_MMA8451.h>  //accelerometer
#include <Adafruit_Sensor.h>
#include <SoftwareSerial.h> //for wireless transmission with the xbee
Adafruit_MMA8451 mma = Adafruit_MMA8451();
SoftwareSerial XBee(2, 3);
void setup(void) {
  Serial.begin(57600);
  XBee.begin(57600);
  Serial.println("Here we go!");
  #ifdef AVR
    Wire.begin();
  #else
    Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
  #endif
  if (! mma.begin()) {
    Serial.println("Couldnt start");
    while (1);
  Serial.println("MMA8451 found!");
  mma.setRange(MMA8451_RANGE_2_G);
  Serial.print("Range = "); Serial.print(2 << mma.getRange());
  Serial.println("G");
void loop() {
  XBee.write(Serial.read());
  // Read the 'raw' data in 14-bit counts
  mma.read();
  Serial.print("X:\t"); Serial.print(mma.x);
  Serial.print("\tY:\t"); Serial.print(mma.y);
  Serial.print("\tZ:\t"); Serial.print(mma.z);
  Serial.print("\t");
  Serial.print("t:\t"); Serial.print(millis());
  Serial.println();
delay(20);
On the Matlab side, I simplified my code down to this:
Code:
close all
clear all
clc
%% Setup
% Clears open COM ports that are already in use by MATLAB
instrreset
% Sets communication channel with the sensor to COM4
s = serial('COM4');
% Sets the baud rate for the connection
% This must be the same baud rate of the XBee transmission
set(s, 'BaudRate', 57600);
% Opens the communication channel with the sensor
fopen(s);
%% Initializing Variables and setting up data matrix
% Initializing variables
Number_of_Samples = 500;
i = 1;
j = 1;
k = 1;
l = 1;
x = [];
y = [];
z = [];
time = [];
t_arduino = [];
t_difference = [];
data = [];
% Startup messages
fprintf('Setup complete. \nStarting data collection.\n');
figure();
hold on
grid on
axis auto
xlabel('Time (seconds)');
ylabel('x, y, and z 4096/g');
title('Real Time Accelerometer Data');
t1 = clock;
while i <= Number_of_Samples
    Line = fgets(s)
    Raw_Data = sscanf(Line, '%*s%f');
    Size = size(Raw_Data);
    for j = 1:Size(1)
        %Gets placed in the x-data column
        if mod(j, 4) == 1
            data(l,k) = Raw_Data(j);
            x_temp = Raw_Data(j);
            x = [x x_temp];
            k = k + 1;
        end
        %Gets placed in the y-data column
        if mod(j, 4) == 2
            y_temp = Raw_Data(j);
            y = [y y_temp];
            k = k + 1;
        end
        %Gets placed in the z-data column
        if mod(j, 4) == 3
            z_temp = Raw_Data(j);
            z = [z z_temp];
            k = k + 1;
        end
        %Gets placed in the time column
        if mod(j, 4) == 0
            t_arduino_temp = Raw_Data(j);
            t_arduino = [t_arduino t_arduino_temp];
            t2 = clock;
            t_temp = etime(t2,t1);
            time = [time t_temp];
            l = l + 1;
            k = 1;
        end
    end
     plot(time, x, 'r', time, y, 'k', time, z, 'b')
     legend('x', 'y', 'z')
    if mod(i, 50) == 0
        drawnow
        %fprintf('Collected %d samples. \n', i)
    end
    i = i + 1;
end
%% Finishing up
% Housekeeping - close and clean up all data streams
fclose(s);
fclose(dat);
delete(s);
clear s;
Likes berkeman
I'd get rid of the X,Y,Z,T stuff. Its unneeded as you know the order of your data.
And I'd get rid of the \t characters as also unneeded and use spaces or if its better in your MATLAB code use commas as in comma separated values (CSV) file format.
Also I'd combine the four prints into one print line call.
Related to Communication between Arduino and Matlab Help
1. How can I establish communication between an Arduino and Matlab?
To establish communication between an Arduino and Matlab, you will need to connect the Arduino to your computer via USB and install the necessary drivers. Then, you can use the serial communication functions in Matlab to send and receive data from the Arduino.
2. How do I send data from Matlab to Arduino?
You can use the "fprintf" function in Matlab to send data to the Arduino through the serial port. Make sure to use the correct baud rate and data format for successful communication.
3. Can I control the Arduino from Matlab?
Yes, you can use the "serial" function in Matlab to open a serial connection with the Arduino and then send commands to control its inputs and outputs. You can also use the "arduino" function to create an Arduino object and control it using its methods.
4. What is the best way to troubleshoot communication issues between Arduino and Matlab?
If you are experiencing communication issues between Arduino and Matlab, first make sure that the hardware connections are correct and that the serial port is selected correctly. You can also use the "serialportlist" function in Matlab to check for available ports. Additionally, check for any error messages in the Matlab command window and refer to the official documentation for troubleshooting tips.
5. Is there a way to record data from Arduino in Matlab?
Yes, you can use the "fscanf" function in Matlab to read data from the serial port and store it in variables. You can also use the "read" method of the Arduino object to continuously read data from the Arduino and save it in a file. Additionally, you can use the "plot" function to visualize the data in real-time.
