Communication Theory vs. DSP? Differences?
In summary: Comm. theory is more focused on the theory of communication, which includes understanding the signal and the noise that goes along with it.
DrummingAtom
659
I have a choice between these two courses next semester and I want to learn a little more about them before I make my decision. Does DSP construct a received signal? While Comm. Theory would focus on creating the signal and dealing with noise?
Thanks
Comms Theory is like it says the theory of communication. It is primarily mathematical. DSP is also a mathematical theory but it is of wider scope the Communication Theory. DSP is everything from coding for communications, to audio processing, image processing and more.
They are quite different courses. What are your career goals? In communication theory you will sometimes use DSP to demonstrate algorithms, but really you're more likely to use MATLAB. In DSP you'll also use MATLAB but you'll have a different (but overlapping) focus.
Thanks for the reply.
I'm not exactly sure of my career goals yet because I still know so little about all the different EE fields. If I had to guess though it would be RF, optics, DSP, controls, or even straight software.
Go to campus bookstore and spend some time looking through the required books and see which one peaks your interest the most. This is what I did (albeit years ago).
Thanks for the reply. Actually, I did check out some books but I'm still having trouble deciding which to take.
From what I gathered Comm. theory would be creating and sending a signal knowing that the channel might be noisy and then understanding what that signal is upon received with the added noise. DSP seems like only putting the signal back together in the fastest most efficient way possible with the end result of that signal being used in a digital system. I searched for related jobs too and most of the results I've found said either Comm. theory knowledge and/or DSP. If I only took one of these classes would it matter in terms of jobs?
I'm considering taking both courses as of now; would that be redundant? Both courses seem to have a lot of overlap in terms of Fourier stuff and filters. But I noticed that Comm. theory seems to use a lot of probability while DSP does not.
They aren't redundant at all. I took both myself. You'll eventually need to take an intensive course in Random Signals and Noise to really understand either Comms theory or DSP.
The way to really figure out what you want to do is to take classes in everything. It's hard to tell without getting your hands dirty if you'll like something.
To me at least, communications theory is more philosophically interesting. What is a signal, and what is noise?
Digital signal processing is more the mechanics of coding and decoding from one kind of format into another. Highly mathematical.
Related to Communication Theory vs. DSP? Differences?
1. What is the main difference between communication theory and DSP?
The main difference between communication theory and DSP (digital signal processing) is that communication theory focuses on the study of how information is transmitted and received through various communication systems, while DSP focuses on the analysis and manipulation of digital signals to improve their quality or extract useful information from them.
2. How do communication theory and DSP relate to each other?
Communication theory and DSP are closely related as both deal with the processing and transmission of signals. Communication theory provides the foundation for understanding how signals are transmitted and received, while DSP provides the tools and techniques for analyzing and manipulating these signals.
3. Can communication theory be applied to analog signals as well?
Yes, communication theory can be applied to both analog and digital signals. While DSP is specifically focused on digital signals, communication theory covers the principles and techniques for both analog and digital communication systems.
4. How does DSP impact communication systems?
DSP plays a crucial role in improving the performance of communication systems. By processing digital signals, DSP can remove noise and distortion, increase signal strength, and improve overall signal quality. This leads to more reliable and efficient communication systems.
5. Are both communication theory and DSP equally important in the field of communication engineering?
Yes, both communication theory and DSP are essential in the field of communication engineering. Communication theory provides the theoretical foundation for understanding how information is transmitted and received, while DSP provides the practical tools for analyzing and improving the quality of signals in communication systems.
  • STEM Academic Advising
  • Electrical Engineering
