MHB Commutative rings are IBN-rings - Bland Proposition 2.2.11
  • Thread starter Thread starter Math Amateur
    Rings
The discussion centers on understanding Proposition 2.2.11 from Paul E. Bland's book on rings and modules, specifically regarding the proof that all bases of a free R-module have the same cardinality. Bland defines a commutative ring R and constructs a vector space from the free module F, showing that two bases of this vector space correspond to the bases of F. By proving that the dimensions of the vector space are equal for both bases, it follows that the cardinalities of the bases of F are also equal. The participants clarify the logic behind this proof, confirming that the argument holds and resolves the initial confusion. The conclusion emphasizes the consistency of cardinality across bases of free R-modules.
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am trying to understand Section 2.2 on free modules and need help with the proof of Proposition 2.2.11.
Proposition 2.2.11 and its proof read as follows:View attachment 3588
Proposition 2.2.11 relies on the definition of an IBN-ring so I am providing Bland's definition of an IBN-ring which reads as follows:
Now in the proof of Proposition 2.2.11, Bland defines $$R$$ as a commutative ring ... ... and then has to show (see above definition of an IBN-ring) that for every free $$R$$-module $$F$$, any two bases of $$F$$ have the same cardinality.Bland then considers a free module $$F$$ ... ... ... ... BUT ... instead of considering bases of $$F$$ ... ... ... ... Bland, instead, shows that $$\{ x_\alpha + F \mathscr{m} \}_\Delta$$ is a basis for the vector space $$F/F \mathscr{m}$$ ... ... and also shows that $$\text{dim}_{R/ \mathscr{m}} ( F/F \mathscr{m} ) = \text{ card } ( \Delta )$$
... ... and then shows that
$$\text{ card } ( \Delta ) = \text{ card } ( \Gamma )$$
for any other basis $$\Gamma$$ of the vector space $$F/F \mathscr{m}$$
BUT ... ... we should be showing that all bases of $$F$$ (and NOT $$F/F \mathscr{m}$$ ) have the same cardinality ? !... ... so then ... ... how has Bland shown that every free $$R$$-module $$F$$ of the ring $$R$$ has bases of the same cardinality?Could someone explain the logic of Bland's proof of Proposition 2.2.11 ...
I would really appreciate help ...
Peter
Hi Peter,Bland considers two bases with set of indices $$\nabla, \Gamma $$ of the free module $$F$$ and then , in order to show they have the same cardinality, he constructs a vector space over $$R$$ in such a way that two basis of the vector space has cardinality $$card(\nabla),card(\Gamma)$$.
Hence $$card(\nabla)=card(\Gamma)$$ (Becasuse it is proved that two bases of a vector space has the same cardinality) and then the cardinality of the two initial bases of $F$ is the same.
Hi Fallen Angel,
Thanks so much for your help ... really appreciate it ...
Now ... ... just reflecting on your argument ...
So you are saying that $$\{ x_\alpha + F \mathfrak{m} \}_{ \Delta }$$ and $$\{ x_\beta + F \mathfrak{m} \}_{ \Gamma }$$ are not only bases for the vector space $$F/ F \mathfrak{m}$$ ... ... BUT ... are also bases for $$F$$ as well?
But I do not see how they are bases for $$F$$.
Are you able to explain how they are bases for $$F$$ ... ?
Sorry to be slow ... and not follow you exactly ...
PeterPS By the way, thanks for you help with the symbol $$\mathfrak{m}$$***EDIT*** ***EDIT*** ***EDIT***oh! thanks to you, I think I now see the logic ... I was not reading the proof carefully enough ...
We start with a basis $$ \{x_\alpha \}_\Delta $$of cardinality $$\Delta$$ and then construct a basis (of the same cardinality) $$\{ x_\alpha + F \mathfrak{m} \}_{ \Delta }$$ of the vector space $$F/ F \mathfrak{m}$$.Then we consider another basis $$ \{ \overline{ x}_\beta \}_\Gamma $$ ... ... and through the same argument show that
$$\{ \overline{x}_\beta + F \mathfrak{m} \}_{ \Gamma }$$
is also a basis of the vector space $$F/ F \mathfrak{m}$$
Then since the dimension of a vector space is unique, we have
Is that correct?
Yeah, you got it! :D
Yes, thanks to you!
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
