Commutator of creation/annihilation operators (continuum limit)
In summary, the conversation discusses Example 3.6 in Section 3.5 of 'QFT for the Gifted Amateur' by Lancaster & Blundell, which uses the commutator [a^{\dagger}_\textbf{p}, a_\textbf{p'}] = \delta^{(3)}(\textbf{p} - \textbf{p'}) to calculate \langle\textbf{p}|\textbf{p'}\rangle. The third and last step of the calculation involves taking out the Dirac delta as it represents either 0 or infinity, resulting in \langle\textbf{p}|\textbf{p'}\rangle = \delta^{(3)}
soviet1100
50
Hi,
This is a question regarding Example 3.6 in Section 3.5 (p.35) of 'QFT for the Gifted Amateur' by Lancaster & Blundell.
Given, [itex] [a^{\dagger}_\textbf{p}, a_\textbf{p'}] = \delta^{(3)}(\textbf{p} - \textbf{p'}) [/itex]. This I understand. The operators create/destroy particles in the momentum state p and p'.
However, the authors use this commutator in example 3.6 to calculate [itex] \langle\textbf{p}|\textbf{p'}\rangle [/itex] as follows:
[itex] \langle\textbf{p}|\textbf{p'}\rangle = \langle0| a_\textbf{p}a^{\dagger}_\textbf{p'} |0\rangle [/itex]
[itex] \hspace{12mm} = \langle 0| [\delta^{(3)}(\textbf{p} - \textbf{p'}) \pm a^{\dagger}_\textbf{p'} a_\textbf{p}]| 0\rangle [/itex]
[itex] \hspace{12mm} = \delta^{(3)}(\textbf{p} - \textbf{p'}) [/itex]
I understand the second step too; +/- for bosons/fermions depending on whether a commutator or anticommutator is used. It's the third and last step that I don't understand. How does that follow from the second?
## a_{\mathbf p} ## is an annihilation operator, which means ## a_{\mathbf p}|0\rangle=0 ##, so the term ## \langle 0|a_{\mathbf p'}^\dagger a_{\mathbf p} |0\rangle ## is zero. The other point is that the Dirac delta there is representative of 0 or ## \infty ## which means its a number and you can take it out to gain ##\langle 0|\delta^{(3)}(\mathbf{p-p'}) |0\rangle=\delta^{(3)}(\mathbf{p-p'}) \langle 0|0\rangle=\delta^{(3)}(\mathbf{p-p'}) ##.
Likes soviet1100
Ah, I get it now. Thanks a ton for the help.
Related to Commutator of creation/annihilation operators (continuum limit)
What is a commutator of creation/annihilation operators in the continuum limit?
In quantum field theory, creation and annihilation operators are mathematical operators that are used to describe the creation and destruction of particles. In the continuum limit, these operators are expressed in terms of quantum fields, which are continuous functions of space and time. The commutator of these operators is a mathematical expression that describes how the operators interact with each other.
What does the commutator of creation/annihilation operators tell us?
The commutator of creation/annihilation operators tells us about the fundamental properties of quantum fields, such as their commutation relations, which are crucial in understanding the behavior of particles in quantum systems. It also helps us calculate important quantities, such as the energy spectrum and scattering amplitudes.
How is the commutator of creation/annihilation operators calculated in the continuum limit?
The commutator of creation/annihilation operators is calculated using a mathematical expression known as the commutator bracket. In the continuum limit, this bracket is expressed in terms of the field operators and their derivatives, and it depends on the specific quantum field theory being studied.
What are some applications of the commutator of creation/annihilation operators in physics?
The commutator of creation/annihilation operators has many applications in various branches of physics, such as quantum mechanics, quantum field theory, and statistical mechanics. It is used to study the behavior of particles in high energy physics, condensed matter physics, and cosmology. It is also an essential tool in the development of quantum computing and quantum information theory.
Are there any limitations to using the commutator of creation/annihilation operators in the continuum limit?
While the commutator of creation/annihilation operators is a powerful mathematical tool, it does have its limitations. It is based on the assumption that the quantum field is continuous, which may not always hold true in certain physical systems. Additionally, the continuum limit may not be applicable in certain extreme conditions, such as near black holes or at the beginning of the universe, where the discrete nature of space and time becomes important.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
