B Commutators of functions of operators
LagrangeEuler
I would like to ask whether if operators ##A## and ##B## commute also operators ##e^A## and ##e^B## commute? Also I have a question is it possible that
##e^A## is matrix where all elements are ##\infty## so that ##e^A \cdot e^B-e^B\cdot e^A## has all elements that are ##\infty##?
Have you tried to prove that?
That makes no sense. Matrices cannot have infinite elements.
I would try to prove that by showing with mathematical induction that any partial sum MacLaurin expansions ##\displaystyle\sum\limits_{k=0}^{N}\frac{1}{k!}A^k## and ##\displaystyle\sum\limits_{k=0}^{N}\frac{1}{k!}B^k## with a finite ##N## commute when ##[A,B]=0##. It results just from the fact that ##A^m B^n = B^n A^m## for any ##m,n\in\mathbb{N}## when ##[A,B]=0##, so the order of operators doesn't make any difference when forming that polynomial of two operator variables.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
