Comparable size of the observable universe immediately after inflation
In summary, the size of the observable universe immediately after early inflation is difficult to determine. Estimates vary widely, with some scientists suggesting it was the size of a marble and others estimating it to be 10^30 times larger than before inflation. The expansion rate changed quickly after inflation, going from accelerating to decelerating and passing through different energy components. However, the expansion of the universe remained uniform throughout space and is responsible for the Hubble flow. The scalar field responsible for inflation flattened out after the inflationary epoch ended and the universe entered into a slow roll inflation. The Hubble constant was very large during this time but has since declined.
Herbascious J
165
Regarding scale. How big was the region of the universe we now understand to be the observable universe, immediately after early inflation? I'm tyring to understand the scale. I know our sphere of observation is very approximately 45 billion light years or something, I don't know for sure, but I am curious to get a feel for how much expansion took place after inflation (according to scientists like Alan Guth). Was it the size of the Milky Way Galaxy? Thank you in advance.
Space news on Phys.org
Pretty certain that after inflation it was about the size of a grape fruit...
It is very difficult to quantify the size of the observable universe after inflation ended. We do not know how 'big' it was when inflation started, how rapidly it doubled in size ['inflated'], or how long the inflationary period persisted. Estimates of size after inflation vary wildly. Alan Guth guestimated it was around the size of a marble. Lineweaver estimates the universe grew by a factor of ~10E30 during inflation - re: http://arxiv.org/abs/astro-ph/0305179v1. By that standard, if you assume the observable universe was a Planck length prior to inflation, you end up with a size of about 1.6E-05 meters after inflation. If you assume it was the size of a proton, you get a universe of about 1.6E15 meters, or around 1/10 the size of our galaxy.
Wow, that is a wide range... Ok, so what I see then is that the region was appreciably smaller than the observable universe now. So, the velocity of expansion was quite large, but now things have cooled off so to speak. So my question is; did this 'escape' velocity or expansion remain as aggressive and just continue out into the current Hubble flow, or, once inflation stopped, did the velocities drop significantly at that moment, like a braking? Thanks for the explanations.
The expansion rate changed quickly after inflation: it went from accelerating to decelerating, passing from a vacuum dominated spacetime, through a brief period of matter domination, then to radiation. As the dominant energy component of the universe changes, so does the expansion rate.
I'm confused by your question regarding the "expansion remain[ing] as aggressive and just continu[ing] out into the current Hubble flow" -- the expansion is uniform throughout space and is responsible for the Hubble flow. A key distinction that is important for understanding all this is that between: the metric expansion of space and the growth of the cosmological horizon -- are you comfortable with the difference between these ideas? During inflation, the amount of expansion that the universe underwent was huge (points in space that were 1 'unit' apart at the start of inflation ended up something like 10^26 'units' apart at the end). But the horizon, marking the size of the observable universe, scarcely grew at all during inflation.
Yes, I think I'm clear. I was only using the term 'observable universe' to get a feel for the scale, not to inquire about how it changes over time. Putting things into units like you do above ("points in space that were 1 'unit' apart...") is much more clear. I think I was just trying to ask if the expansion is halted to some degree once inflation stops. I don't think it does, but I wasn't sure.
Under current models, the scalar field responsible for inflation flattened out after the inflationary epoch ended and the universe entered into what is now called slow roll inflation. The Hubble constant was very large during that time, but, has since declined.
The rate of expansion changed after inflation: importantly, it went from accelerating (in the sense that the scale factor, [itex]a(t)[/itex], had a positive second derivative wrt time, [itex]\ddot{a} > 0[/itex]) to decelerating.
I agree with bapowell.
Related to Comparable size of the observable universe immediately after inflation
1. What is inflation in the context of the observable universe?
Inflation refers to the rapid expansion of the universe that occurred in the first fraction of a second after the Big Bang. This expansion was driven by a mysterious force called the inflaton field and it caused the universe to grow exponentially in size.
2. How large was the observable universe immediately after inflation?
The observable universe immediately after inflation is estimated to be about 10^-26 meters in diameter, which is incredibly small compared to its current size of 93 billion light years across. This is because during inflation, the universe expanded faster than the speed of light.
3. How do scientists determine the size of the observable universe after inflation?
Scientists use mathematical models and data from cosmic microwave background radiation to estimate the size of the observable universe after inflation. This is based on the theory of cosmic inflation and the idea that the universe started as a single point of infinite density.
4. Was the observable universe immediately after inflation uniform in size?
No, the observable universe immediately after inflation was not uniform in size. The rapid expansion during inflation caused tiny variations in the density of matter, which eventually led to the formation of galaxies and other structures in the universe.
5. How does the size of the observable universe after inflation compare to its current size?
The size of the observable universe after inflation is minuscule compared to its current size. Inflation caused the universe to expand by a factor of at least 10^26, making it virtually incomprehensible to imagine the difference in size between then and now.
  • Cosmology
  • Cosmology
