MHB Compare P and Q: $a, b, c, d, m, n > 0$
  • Thread starter Thread starter Albert1
    Compare
The discussion focuses on comparing two expressions, P and Q, defined as P = √(ab) + √(cd) and Q = √(ma + nc) × √(b/m + d/n), where a, b, c, d, m, and n are all positive. It is demonstrated that Q^4 is greater than or equal to P^4, which simplifies to showing that (m/n)^2(ad)^2 + (n/m)^2(bc)^2 is greater than or equal to 2abcd, a statement supported by the AM-GM inequality. Further analysis reveals that Q^2 is greater than or equal to P^2, leading to the conclusion that Q is greater than or equal to P. Thus, it is established that Q ≥ P under the given conditions.
Albert1
$a,b,c,d,m,n >0$
$ P=\sqrt {ab}+\sqrt {cd}$
$Q=\sqrt {ma+nc} \times \sqrt {\dfrac {b}{m}+\dfrac {d}{n}}$
$compare\,\, P \,\,and \,\,Q$
Mathematics news on Phys.org
Albert said:
$a,b,c,d,m,n >0$
We show that $Q^4\geq P^4$.
This is same as showing that:
$(m/n)^2(ad)^2+(n/m)^2(bc)^2\geq 2abcd$.
This is clearly true by the AM-GM inequality.
Therefore $Q\geq P$.
My solution:
By applying Cauchy-Schwarz Inequality theorem to Q, we have:
$$Q=\sqrt {ma+nc} \times \sqrt {\dfrac {b}{m}+\dfrac {d}{n}} \ge \sqrt{ma}\sqrt{\frac{b}{m}}+\sqrt{nc}\sqrt{\frac{d}{n}} \ge \sqrt{ab}+\sqrt{cd}= P$$
and equality holds iff $\displaystyle \frac{a}{b}=\frac{c}{d}$.
Albert said:
$a,b,c,d,m,n >0$
$Q^2=ab+cd+\dfrac {mad}{n}+\dfrac {nbc}{m}\geq ab+cd+2\sqrt {\dfrac {mad\times nbc}{mn}}=ab+cd+2\sqrt {abcd}=P^2$
$\therefore Q\geq P$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
