Compare the shadows cast by a pole in the river and a pole on the shore
The discussion centers on the differences in shadow length cast by a pole in water versus on land, primarily due to the behavior of light as it transitions between mediums. The speed of light is slower in water than in air, affecting the angle at which light rays strike the surface and subsequently the length of the shadow. When light rays graze the top of the pole and enter the water, they deflect towards the normal line, resulting in shorter shadows in the water. Ray diagrams illustrate these differences effectively. Understanding these principles highlights the impact of medium on light behavior and shadow formation.
hidemi
A pole stands in a river, half in and half out of the water. Another pole of the same length stands vertically on the shore at a place where the ground is level. The shadow cast by the pole in the river on the river bottom is:
A. slightly longer than the shadow of the pole on land
B. much longer than the shadow of the pole on land
C. shorter than the shadow of the pole on land
D. shorter than the shadow of the pole on land if the Sun is high and longer if the sun is low
E. the same length as the shadow of the pole on land
The answer is C
v=f*λ
Is it because the speed of light is less fast in the water than on land as such leads to different in length of shadow?
Only indirectly.
If you traced a ray of light from the source to the tip of the pole and then straight past that until it strikes the river bottom, that would be the edge of the shadow, right?
What happens to that light ray when it strikes the surface of the river water?
In a way yes. Consider the ray that just grazes the top of the pole. Draw a ray diagram for each of the two cases.
The ray of light would deflect close to the normal line which makes the shadow less longer in the water.
Thanks both of you!
Likes kuruman and jbriggs444
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
