Comparing accuracy of estimators
In summary, the conversation discusses the computation and comparison of estimators for the population mean in terms of accuracy. The variance of an estimator is often used to measure its accuracy, and it is unclear what specific estimators are being compared.
safina
28
May I ask what is needed to be computed in order to compare the estimators of the population mean [tex]\bar{y}_{N}[/tex], in terms of accuracy? That is to compare the multivariate ratio estimator [tex]\bar{y}_{RM}[/tex] with the Y-only estimator [tex]\bar{y}_{n}[/tex] in terms of accuracy.
The variance of an estimator is often used to quantify its "accuracy". Are you asking how to compute the variance of various estimators of the population mean?
I'm not familiar with the multivariate ratio estimator or the Y-only estimator. Can you describe them?
Related to Comparing accuracy of estimators
1. What is the purpose of comparing accuracy of estimators?
The purpose of comparing accuracy of estimators is to evaluate and determine the performance of different statistical methods used for making predictions or estimating unknown parameters. This allows for the selection of the most accurate estimator for a given dataset or research question.
2. How is the accuracy of estimators compared?
The accuracy of estimators can be compared using various statistical measures such as mean squared error, root mean squared error, and mean absolute error. These metrics measure the difference between the estimated values and the true values, with lower values indicating higher accuracy.
3. Can different types of estimators be compared?
Yes, different types of estimators can be compared. This can include comparing parametric and non-parametric estimators, as well as comparing estimators based on different assumptions or approaches.
4. What are some limitations of comparing accuracy of estimators?
One limitation of comparing accuracy of estimators is that it may not always reflect the true performance of the estimator in real-world scenarios. This is because the comparison is based on a specific dataset and may not generalize to other datasets. Additionally, the choice of metric used for comparison can also impact the results.
5. How can the results of comparing accuracy of estimators be used?
The results of comparing accuracy of estimators can be used to inform the selection of the most appropriate estimator for a given dataset or research question. It can also highlight potential weaknesses or limitations of certain estimators, which can help guide future research and improvements in the field of statistics.
