Comparing Energy Transmitted by Light & Sound: Help Needed!
In summary, the energy of a light wave is dependent on the frequency of the incident photon according to E=hf. There is no similar equation for sound waves. Comparing the energies transmitted by light and sound is difficult due to the different types of waves and how they are measured. In a classical situation, the energy in a wave depends not only on the frequency but also the amplitude, making it impossible to make a direct comparison between light and sound waves. However, in terms of quantum mechanics, the energy of a single quantum is the same for both light and sound waves.
macman83
I am aware that the energy of a light wave is dependant solely on the frequency of the incident photon according to E=hf
Is there a similar equation for sound waves to work out the energy transmitted?
If not does anyone have a suggestion on how to compare the energies transmitted by light and sound??
Hope you can help as I'm really struggling to find this info :D
Thanks in advance
Mark
I'm not so sure you can readily compare the energies.
They are very different waves
shame it would have been handy to be able to compare.
Am i correct in saying that the energy of a light wave is likely to be much higher than that of a sound wave?
Try these definitions. You will need to look up the units for yourself.
[tex]EnergyDensity = \frac{{\Pr essur{e^2}}}{{density\;x\;velocit{y^2}}} = \frac{{{P^2}}}{{\rho {c^2}}}[/tex]
[tex]SoundIntensity = rate\;of\;energy\;transfer = \frac{{{P^2}}}{{\rho c}}[/tex]
I'm not so sure...I would have to say no though. You could figure it out with a few equations off of wikipedia most likely.
You would have to generalize a light wave and a sound wave first though. Technically both of the waves could be really high energy, and really low energy.
If you're comparing a single quantum, then they're exactly the same: E = hω for the photon and E = hω for the phonon. Only difference is that ω=ck for the photon and ω=ω(k) for the phonon (dispersion).
But I think what you really have in mind is a classical situation, and you want to compare an electromagnetic wave on one hand to an acoustic wave on the other. And in that case, there's no answer -- the energy in the wave depends not only on the frequency but also the amplitude. A sound can have a greater energy density than a light wave if the sound is loud and the light is dim. Or vice versa.
The classical wave in a medium, while having some relation to the quantum wave, is a very different effect. A wave in water or air is the collective motion of a large amount of particles. The quantum wave describes one single particle at a time. So, while similar, the two are very different and require different math.
FAQ: Comparing Energy Transmitted by Light & Sound: Help Needed!
What is the difference between energy transmitted by light and sound?
The main difference between energy transmitted by light and sound is the medium through which it travels. Light is an electromagnetic wave that can travel through empty space, while sound is a mechanical wave that requires a medium, such as air or water, to travel through.
How is the energy of light and sound measured?
The energy of light is measured in units of joules, while the energy of sound is measured in units of decibels. The energy of light is also often measured in terms of its wavelength or frequency.
Which type of energy is transmitted over longer distances: light or sound?
Light is typically transmitted over longer distances than sound. This is because sound waves tend to lose energy as they travel through a medium, while light waves can travel through empty space without losing energy.
How does the energy of light and sound affect their speed?
The energy of light and sound do not directly affect their speed. However, the medium through which they travel can impact their speed. In general, light travels faster than sound because it does not require a medium to propagate.
What are some common sources of light and sound energy?
Some common sources of light energy include the sun, light bulbs, and fire. Common sources of sound energy include speakers, musical instruments, and human voices.
