Comparing slopes and accelerations in a graph
  • Thread starter Jahnavi
  • Tags
    Graph
In summary, the problem involves two particles A and B moving on the x-axis, with their velocities represented on a velocity-time graph as straight lines. A makes an angle of 120° with the positive x-axis, while B makes an angle of 135°. When comparing the slopes of A and B, it is important to consider the absolute value of the slope rather than the sign, as slope is a different quantity than numbers. Therefore, while the slope of B may be greater than that of A, the acceleration of A is actually greater than that of B due to the negative sign representing the direction of acceleration.
Jahnavi
848
102
There are two particles A and B moving on x-axis .Their velocities are represented on velocity time (v-t) graph . Graphs of both A and B are straight lines . A makes an angle 120° with the positive x-axis whereas B makes an angle 135° .
1) Slope of A or B is more ?
2) Acceleration of A or B is more ?
This is quite a fundamental problem , but the answer key has left me bit confused .
Slope is given by the tangent of the angle measured anticlockwise .
Tan (120°) = - √3
Tan (135°) = - 1
Tan 135° > Tan 120° , so slope of B is more than slope of A
But acceleration will be given by absolute value of the slopes .Is that correct ?
In that case acceleration of A is more than that of B .The negative sign denotes direction .
So , even though slope of B is more than that of A , acceleration of A is more .
Please let me know if I am thinking incorrectly .
Jahnavi said:
Tan 135° > Tan 120 °, so slope of B is more than slope of A
Not quite like that actually. Think like this If we had ##tan(91)=-57## and ##tan(1)=0.017## which one is more steeper ?
The problem in here is describing the "slope" and "steepness". When we compare the slopes we should think as the steepness of the lines.
Jahnavi said:
But acceleration will be given by the absolute value of the slopes.Is that correct?
Without saying acceleration "magnitude" it doesn't sound right, since it's a vector quantity.
As you said negative sign represents that the acceleration is in the negative direction of the velocity.
Isn't definition of slope of a line - tangent of the angle made by the line with the positive x- axis ?
By this definition , isn't slope of B greater than A ?
Slope is a different quantity than numbers. For example -1>-3 yes but we are defining these numbers for a slope.
m=-3 and -3 are not the same thing.
Are you saying that while comparing slopes of two lines , we should compare absolute value of the slopes ( irrespective of their signs ) ?
Yes exactly.
Related to Comparing slopes and accelerations in a graph
What is the difference between slope and acceleration?
Slope is a measure of the steepness of a line on a graph, while acceleration is a measure of the rate at which the velocity of an object changes over time.
How do you calculate slope and acceleration from a graph?
Slope can be calculated by dividing the change in the y-axis values by the change in the x-axis values. Acceleration can be calculated by dividing the change in velocity by the change in time.
Can the slope and acceleration be negative?
Yes, both slope and acceleration can be negative. A negative slope indicates a downward trend on a graph, while a negative acceleration indicates a decrease in velocity over time.
When would you compare the slopes and accelerations in a graph?
Comparing slopes and accelerations in a graph can be useful when analyzing the motion of an object, such as a car or a ball. It can also help determine the relationship between two variables.
What does a steeper slope or a larger acceleration indicate?
A steeper slope or a larger acceleration indicates a faster rate of change in the y-axis values or velocity, respectively. It can also indicate a stronger relationship between the variables being compared.
12K
