Astr0fiend
- 2
This is a statistics as applied to astronomy problem. My stats knowledge is horrible. Anyway, the problem:
For several hundred objects, I have a number of different properties for which I have a measurement & associated measurement error. For example, flux density and its associated error. There is a quantity that has been measured for each source that I need to work with (as explained below), that I'll call 'y'. The variance in 'y' consists of two contributions: Measurement error, which is known with a high degree of precision, and an underlying variation that is a property of the sources themselves, which I'll refer to as the 'intrinsic' contribution.
From the underlying population, I have drawn two samples based on whether or not an object meets some criteria -- the details of this particular criteria are unimportant. I want to compare the variance in 'y' between these two populations due to the intrinsic contribution only.
So the question is this: Is there any way that I can estimate the variance of a sample due to the intrinsic contribution from the objects, given that I know the measurement error on each data point (which differ for all the objects and in mean magnitude for the two different samples)?
Since variance is additive, if the measurement errors were the same for each object I could just use
var(intrinsic) = var(y) - var(meas)
In the presence of unequal measurement errors for each object, I was thinking that some sort of weighted form of the above equation could be used, but not sure. Been looking around for quite a few hours for a solution, but can't quite put it together in my head.
Any help, or being pointed in the right direction would be very much appreciated!
