Comparing two energy systems - two boxes being pushed
In summary: If you take the component units of the Joule you could also split them up as: ##kg \frac{m^2}{s^2}## which looks a lot like mass times velocity squared, or ##M~V^2## :wink:
hairetikos
Starting from rest, two identical boxes are pushed through the same distance. Box A experiences a force F, while box B experience a force 2F. What is true about their final speeds?- The final speed of box A is twice that of box B.
- The final speed of box A is equal to that of box B.
- Something else.
- The final speed of box A is half that of box B.
I also got a hint: "Choose the box as your system, what does the energy principle tell you about the change in kinetic energy? What can you then conclude about the final speeds?"
The chapter this is relevant to is about energy, but I'm not entirely sure if I need an energy equation because I think this is more concept-focused. The equation I tried to use was F=mv.
I tried thinking about F=mvA/t and then 2F=mvB/t. I solved for v in both of these and got vA=Ft/m and vB=2Ft/m. This seems to indicate that one velocity is twice the other. However, I tried that answer and it was wrong. I only have one more try so I want to be fully sure that I understand before I just start guessing.
Right now, I'm torn between saying that the velocities are equal, and that the answer is something else entirely.
Based on the hint above, I'm inclined to think that the two systems have equal total energy, but I'm not sure how this relates to their final velocity.
Thanks in advance for any help!
Logically, if the forces applied are different then you should expect different results.
Looking at the hint, consider the work being done in each case. What equation applies to work done here?
Well, W=F*d. Since the distance is equal for both boxes, but the force is doubled for the second box, the work must also be doubled. But I guess I'm not understanding what this has to do with their velocities. Can you point me in the right direction?
What form does the work that is done take? Hint: The unit of work is energy.
Work is done in joules. Joules can be written as kg * m2 /s2. So I could separate that into N*s * m/s or momentum times velocity, right? That gets me closer to the velocity I think.
Okay, it's good to think about looking at the units. That can often help when you're looking for relationships between values in a problem. It doesn't give you the value of any proportionality constants that might be involved though.
In this case the problem author wants you to practice with the work-energy theorem. Work done on a system ends up as energy in a certain form. What form is that?
Related to Comparing two energy systems - two boxes being pushed
1. How do the energy systems of the two boxes being pushed compare?
The energy systems of the two boxes being pushed can be compared in terms of their efficiency, power output, and the type of energy they use. By analyzing these factors, we can determine which energy system is more suitable for a particular situation.
2. What are the advantages and disadvantages of each energy system?
The advantages of one energy system may be the disadvantages of another. For example, one system may be more efficient but require a higher initial cost. It is important to consider all factors and weigh the pros and cons to make an informed decision.
3. How do external factors, such as friction, affect the comparison of the two energy systems?
External factors like friction can greatly impact the performance of the two energy systems. Friction can cause energy loss and decrease the efficiency of the systems. It is important to take into account these factors when comparing the two systems.
4. Can the energy systems be combined to create a more efficient system?
In some cases, it may be possible to combine the energy systems to create a more efficient system. For example, using a combination of renewable energy sources can provide a more reliable and sustainable energy solution.
5. How can the data and analysis of comparing these energy systems be used in real-world applications?
The data and analysis of comparing these energy systems can be used to inform decision-making in various industries and applications. It can help determine the most cost-effective and sustainable energy solution for a specific situation, leading to more efficient and environmentally-friendly practices.
