Comparing two expenditures of work
  • B
  • Thread starter thetexan
  • Tags
    Work
In summary, the study found that skateboarding is a more energy-intensive activity than walking, and the gross metabolic cost was ~2.2 J kg(-1) m(-1) at the typical speed, greater than that reported for cycling and ~50% smaller than that of walking.
thetexan
269
Let’s say we have two persons who are going to travel from Central Park in New York to the Golden Gate Bridge in San Francisco. One is going to walk and the other is going to use his skate board. And let’s say they weigh the same and take the exact same route.
the question is this...is the same amount of work done (give or take) in both cases? As I understand work, they are both moving the same mass over the same distance albeit using different methods of expenditure of effort.
Another way to ask the question...which would be the better way of travel (considering energy necessary) walk or skate board?
tex
You need to be careful when posing questions of this kind. You say, "the question is this...is the same amount of work done (give or take) in both cases?" "Work done" is too vague. You need to specify the force doing the work. For example, if the persons are initially and finally at rest, the work done by the net force will be zero. If you want the work done by gravity, it will be ##W_g=-mg\Delta h## where ##\Delta h## is the vertical displacement of the persons. If you want the work done by air resistance, ##\dots~## it's complicated.
Likes Bystander
There is also a difference between physics and physiology. In physiology, a person uses energy (work) even when standing still.
So if you phrased your question using only machines, not biology, it would be clearer that you are asking about physics.
It's not an original question. Did you try searching the web with google or the like?
https://pubmed.ncbi.nlm.nih.gov/25085605/
"Self-selected speeds and metabolic cost of longboard skateboarding"
Eur J Appl Physiol, 2014 Nov
"...The gross metabolic cost was ~2.2 J kg(-1) m(-1) at the typical speed, greater than that reported for cycling and ~50% smaller than that of walking."
Likes jrmichler
FAQ: Comparing two expenditures of work
What is the purpose of comparing two expenditures of work?
The purpose of comparing two expenditures of work is to determine which one is more efficient and effective in achieving a desired outcome. By comparing the amount of effort, time, and resources required for each expenditure, we can make informed decisions on how to allocate resources and improve processes.
How do you measure the amount of work expended?
The amount of work expended can be measured in various ways, depending on the nature of the work. Some common metrics include time, cost, energy, and resources used. For example, in a manufacturing setting, the amount of work expended can be measured by the number of units produced in a certain time period.
What factors should be considered when comparing two expenditures of work?
When comparing two expenditures of work, it is important to consider the goals and objectives of the work, the resources available, the time frame, and the expected outcomes. Other factors that may influence the comparison include the complexity of the work, the skills and expertise required, and potential risks or challenges.
How can you ensure a fair comparison between two expenditures of work?
To ensure a fair comparison between two expenditures of work, it is important to establish clear criteria and metrics for evaluation. This can include setting specific goals and objectives, defining the scope of work, and identifying the key performance indicators. It is also important to gather accurate and reliable data for both expenditures to avoid any bias in the comparison.
What are some potential benefits of comparing two expenditures of work?
Comparing two expenditures of work can lead to several benefits, such as identifying inefficiencies and opportunities for improvement, optimizing resource allocation, and increasing productivity and effectiveness. It can also help in making data-driven decisions and setting realistic goals for future projects. Additionally, comparing expenditures of work can foster healthy competition and drive innovation within a team or organization.
