Comparing two functions and determining coefficients. I get 1/1.
In summary, the objective is to compare two equations and find the coefficients k1 and k2. By setting k1 and k2 as functions of R1 and R2, the equations can be expanded and rearranged to find the values of R1 and R2. The solution for R1 and R2 can be derived from a more general equation for a cylinder without internal heat generation. It is important to note that k1 and k2 must add up to 1 and the area available for heat flow must be taken into consideration when calculating thermal resistance.
Mamed
The objective is to find some coefficients by comparing two equations.
[itex]
T_2 \cdot \frac{R_1}{R_1+R_2} + T_1 \cdot \frac{R_2}{R_1+R_2} [/itex]
and
[itex]T_2 \cdot k_1 + T_1 \cdot k_2[/itex]
I compare and set
[itex]k_1 = \frac{R_1}{R_1+R_2} (1)[/itex]
[itex]k_2 = \frac{R_2}{R_1+R_2} (2)[/itex]
I expand the equations and throw them around
[itex](1) -> R_1 = R_2 \cdot \frac{k_1}{1-k_1} (3)[/itex]
[itex](2) -> R_2 = R_1 \cdot \frac{k_2}{1-k_2} (4)[/itex]
I put in (3) in (4) and get
[itex]R_2 = R_2 \cdot \frac{k_1}{1-k_1} \cdot \frac{k_2}{1-k_2} -> 1 = \frac{k_1}{1-k_1} \cdot \frac{k_2}{1-k_2}[/itex]
So i don't know how to get the values of [itex]R_1[/itex] and [itex]R_2 [/itex] as a function of [itex] k_1 [/itex] and [itex]k_2.[/itex]
The solution for this is given and is correct when I put it in the equations above and it fulfills everything but i just don't know how he has gotten it.
[itex]k_x[/itex] is a long function based on parameters that i just rebrand for simplicity.
Mathematics news on Phys.org
[itex]
and
If those are two equations then where are the "=" signs? Do you mean "functions" instead of "equations"? Are the two functions assumed to be equal?
No they have it all expressed as
[itex]
T_m = T_2 \underbrace{\left( \frac{\displaystyle r_2^2}{\displaystyle r_2^2-r_1^2}-\frac{\displaystyle 1}{ \displaystyle 2 \ln{\left( \displaystyle r_2 / r_1 \right) }} \right)}_{k_1} + T_1
\underbrace{\left( \frac{ \displaystyle 1}{\displaystyle 2 \ln{\left(\displaystyle r_2 / r_1 \right) }}-\frac{\displaystyle r_1^2}{\displaystyle r_2^2-r_1^2} \right)}_{k_2}
[/itex]
and then they have the equation as i have given above
[itex]T_m = T_2 \cdot \frac{\displaystyle R_1}{\displaystyle R_1+R_2} + T_1 \cdot \frac{\displaystyle R_2}{\displaystyle R_1+R_2}[/itex]
And then they say "Comparing the coefficients of [itex]T_1[/itex] and [itex]T_2[/itex] in the two equations we get"
[itex]
R_1 = \frac{1}{\displaystyle 4\pi kL} \left( \frac{\displaystyle 2r_2^2\ln{\left(r_2/r_1\right)} }{\displaystyle r_2^2-r_1^2}-1 \right)
[/itex]
[itex]
R_2 = \frac{1}{\displaystyle 4\pi kL} \left( 1- \frac{\displaystyle 2r_1^2\ln{\left(r_2/r_1\right)} }{\displaystyle r_2^2-r_1^2} \right)
[/itex]
What i want to know is how they arrive at the values for [itex]R_1 [/itex] and [itex]R_2[/itex]
There must be something else you are not telling because the equations for R1 and R2 contain 1/(4.pi.k.L) ...which is nowhere in the coefficients k1 and k2...
Those are for thermal conductivity and and the length, when you put them in the equation they are canceled out.
Tm is a mean temperature in an lumped parameter cylinder with no internal heat generation. And that's how they arrive at the solution. No further explaining done. And i want to know how they arrive at the solution rather than just look at the solution. Not holding back anything.
Then, maybe you need to reveal the entire problem at hand...we are driving blind here...without knowing the context...maybe if we knew more...for example, you just revealed that we are talking about a cylinder without internal heat generation...what can you tell about T1 and T2, where are they supposed to be?
Sparing us from the details is not working...tell us everything, now.
lol ok, the r2 is outer radius at temperature T2 and r1 is inner with T1. L is the length.
And the resistance is set so that
T1----R1-----Tm------R2------T2--->Q
If we use Ohms law here, then Tm = T2+Q*R2
We know that Q = (T1-T2)/(R1+R2) -> Tm = T2 + R2*(T1-T2)/(R1+R2)
Tm = T2*R1/(R1+R2) + T1*R2/(R1+R2)
Thats the equation form the beginning and then he has the other equation that he compares with which i have already given. And then he magically arrives at that solution.
That specific equation he derives form a cylinder with the equationd^2T/dr^2 + 1/r* dT/dr + g/k = 0 but here g = 0 as there is no internal heat generation.
Hhhmmm..
So, if R1 and R2 add up to the total thermal resistance in the radial direction of the cylinder (tube, rather)...then
R1/(R1+R2) is a fraction of it (a number less than 1.0), and
R2/(R1+R2) is another fraction ( <1.0) and complementary...
meaning, together, they add up to 1, correct?
R1/(R1+R2) + R2/(R1+R2) = (R1+R2)/(R1+R2) = 1.0
that means that also k1+k2=1 ...the knowledge of this may help you in your calculations
Also, those formulas about the thermal resistance look too complicated...why do you have r2 in there? Make sure that when calculating the thermal resistance you do not mix what the cross-sectional area available for heat flow is...in other words, if the heat is flowing from the inside wall of the cylinder to the outside wall...the area for flow at a given radius is 2∏rL ...this appears in the denominator of the formula for resistance:
dR = dr/(2∏rLκ)
when you integrate this over a given range, you do not have r2, you just get a difference of ln:
(ln(R2)-ln(R1))
Now, if the heat is flowing in the axial direction of the cylinder, well, then the area available for heat flow does include r2...so, just make sure you have all your ducks in a row...
Related to Comparing two functions and determining coefficients. I get 1/1.
1. How do I compare two functions?
To compare two functions, you can graph them on the same coordinate plane and look for similarities and differences in their shape, intercepts, and slopes. You can also use algebraic methods such as substitution or elimination to determine if the functions are equivalent.
2. What are coefficients in a function?
Coefficients in a function are the numbers multiplied by the variables. For example, in the function y = 2x + 3, 2 is the coefficient of x and 3 is the constant term.
3. How do I determine the coefficients of a function?
To determine the coefficients of a function, you can look at the equation and identify the numbers multiplied by the variables. You can also use the slope-intercept form, y = mx + b, where m is the slope (coefficient of x) and b is the y-intercept (constant term).
4. What does the fraction 1/1 mean in the context of comparing two functions?
The fraction 1/1 in the context of comparing two functions means that the functions are equivalent, or have the same slope and y-intercept. This can also be written as y = x + 0, where the coefficients of both functions are 1.
5. Can two functions have the same coefficients but different graphs?
Yes, two functions can have the same coefficients but different graphs. This can happen if the functions have different exponents or coefficients of other variables. For example, y = 2x and y = 2x^2 have the same coefficient of x, but their graphs are different.
  • General Math
  • General Math
