bottles
- 1
For simplicity, I'm leaving out extraneous details (like actual numbers). Also, apologies for my formatting; I don't know how to use Latex, but I tried to make this as readable as possible. I have a set of N measurements for τ which each have their own standard deviations, and I need to determine whether the weighted average of the N measurements is significantly different from the weighted average of the first n (= N-2) of the measurements.
I've read a bunch on t-tests, but I'm confused and not sure how to use one. Part of the problem is that I don't know exactly what true means/variances refer to (so I don't know if they're known or unknown in this case). I considered using a paired test somehow, but I don't think that will work since the sample sizes are different. This is for a physics assignment, but I'm trying to answer a question asking me to discuss the difference in the two means, and I don't know how to do that other than with testing for statistical significance (and I don't know how to do that in this case... things were so much more clear back in Intro to Statistics).
I'm getting most of my information about this from https://controls.engin.umich.edu/wiki/index.php/Comparisons_of_two_means. These are the four tests that wiki lists:
- σ = the known standard deviation of the population
- s = the standard deviation of the data set
- |a| = average of a
I. unknown true means; sample standard deviations approx. equal:
t = [(|x1|-|x2|)/Spooled]*√[Nn/(N+n)]
Spooled = √{[s21(N-1) + s22(n-1)]/(N+n-2)}
II. unknown true means; known, true, unequal standard deviations:
z = (|x1|-|x2|)/√[σ21/N + σ22/n]
III. unknown true means; unknown true standard deviations:
t = (|x1|-|x2|)/√[s21/N + s22/n]
IV. paired data:
t = |d|/(sd/√N)
|d| = the mean of the differences for a sample of the two measurements
sd = the standard deviation of the sampled differences
N = the number of measurements in the sample
I've done this so far:
weighted averages:
μN = Ʃ(xi/σ2i)/Ʃ(1/σ2i)
μn = Ʃ(xi/σ2i)/Ʃ(1/σ2i)
standard deviations in the weighted means:
σN = √[1/Ʃ(1/σ2i)]
σn = √[1/Ʃ(1/σ2i)]
difference in the means:
Δτ = |μN-μn| ± √[σ2N + σ2n]
The first four are equations given by the professor for other parts of the assignment. They're supposed to give a 68.3% chance of the true value lying within μ ± σ and a 95.5% of the true value lying within μ ± 2σ. I want to believe that 95.5% means I have a 95.5% confidence interval, but that seems off to me. Also, I don't know whether the σ in these equations is the same as the σ in the equations I found for the t-test.
Any help would be much appreciated.
